What's your kayak rack setup?
halligan1201
Byron, IL
2020 Ranger
Emergency Management
It’s a great setup. Pretty easy install also. Got it from Stage 3 Motorsports. They’re a sponsor on this forum.
How high is yours set in that picture?
landiscarrier
Landis
Pocono Mtns Pa
2025 Ranger Raptor
Sales
My set up is the bed. I specifically bought my Ranger because I was tired of car topping my wife’s and my kayak.
I open the tail gate and put them in the bed. I’ve put up to 4 kayaks in the bed and 3 of them are 12ft plus heavy fishing kayaks.
WV_Ranger
Truck
Same. I've driven thousands of miles with canoes and kayaks strapped in a 6'5" bed, the 6' bed of my ranger will have no problem hauling the same way! Plus I'd hate to lift my fishing yak onto racks. After a long day of not catching fish I'm usually pretty tired. ?
Stevedbvik1
2022 Ranger Tremor XLT
Kinda hard to do when you’re towing this
CHS
chris
Crossville, TN
(Ruby) 2021 Ford Ranger Lariat 4X4
Question: Do you all mount the kayaks right side up or down?
I own a 12-8" Sit on top angler kayak. I have it mounted on a rack on top of a Smart Cap. If I keep it right side up it can get water in it. If I turn it upside down, it does not fit correctly on the Yakima feet.
Really getting tired of buying crap so I can carry it.
Can I just mount it upside down directly onto the crossbars? Will it damage it somehow. I would think that the straps should hold it down well enough not to go anywhere.
halligan1201
Byron, IL
2020 Ranger
That's how I get to and from local spots. If I'm going further I use a hitch extension. Now I'm adding option 3 because I also want to be able to bring them with on my longer camping trips and want the bed back for camping gear.
khyros
2019 Ford Ranger Lariat Crewcab FX4
I mean, at a minimum, cut of a pool noodle and put it over the crossbar. The cheapest and simplest racks I've seen have basically been that... I want to say its a strap that goes through the car doors with a buckle, and then a little air bladder to provide some padding for your kayak. Keep in mind that the entire pressure you're putting on the kayak to hold it in place ends up being resisted by whatever contacts the kayak/roofrack. So the smaller that surface, the more concentrated the force, and the higher likelihood of damaging your kayak.
As far as right side up vs. upside down... It shouldn't matter since you have a sit on top. The scupper holes drain the water anyways. Just make sure your hatches are sealed. If you had a sit in kayak, I would recommend right side up with a cockpit cover. But of course, that's another thing to buy :) If you're using a pool noodle, you can put it upside down and secure it that way as the cheapest way to the lake. And depending on how much you spent on your kayak, that might be the right answer. Just keep in mind that proper transportation will extend the life of your kayak, so if it is expensive (and especially if it's fiberglass) you'll want to transport it the right way.
halligan1201
Byron, IL
2020 Ranger
Got this installed today. Truxedo Elevate rack with TS rails and a LoPro roll up cover. Still need to figure out kayak mounts for the bars yet.
Did you ever decide on which kayak mounts? I'm having trouble determining which ones work with the Elevate.
Stevedbvik1
Still kicking it around. Thule, Yakima and Rhino Rack all make t slot flat carriers that work. Expensive. Also looking at some foam blocks that fit around the rail. Still trying to confirm dimensions with supplier. Will probably go that route as it’s waaayyyy cheaper. I can dig up some links if you want
mtsoxfan
NEK VT
I just toss in the bed. After 6 years oflifting ontop of SUV, I wanted easy. In the bed is the easiest and quickest IMHO...
Stevedbvik1
Doesn’t work when you’re towing a 23ft travel trailer.
halligan1201
Byron, IL
2020 Ranger
I saw those flat ones and thought the same thing about price. I might end up with foam too so if you have links to what you think might work that'd be great!
Stevedbvik1
Stevedbvik1
Malone has these also but only 14” length
