What the right PSI ?
McLeadslinger
Trevor
Pikeville NC
Aircraft Electrician
You can’t chalk all off road tires. Some dont have a flat tread surface.
Experienced guess..32 if they are E load range 36 if C.
Gotta chalk. Tweak to your liking.
AZRanger
Lane
Arizona
2021 Ranger XLT FX4
I fix Pink jeeps
I just put my 285s on but I’m still experimenting. 20 psi seems pretty comfortable for general trail use. Currently running 35 on road.
How’s those 285’s going for ya?
I have 305’s.. they are absolutely beautiful, but my PSI & MPG, is just out of control lol… 16-16.5MPG.
Mine are on track to hit their promised 60K...although I hate the last 10-15K as they will start to look visibly worn but still have legal tread depth...
How tall are those 305?
My Coopers have flat contact blocks and chalk test with 37 cold-40 hot, at my weight of 5,000-5,500lbs shows full flat contact...your results may differ...
IdahoRanger
Idaho
2019 Lariat SuperCrew FX4
RETIRED
Had " The Works" done yesterday. 3 out of 4 tires measured 8mm and one 7. They have 21k miles on them.
They must not have measured the edges that show my hard cornering.
Dieseldean1
Reno
2020 Ranger
Go with indicated pressure on the sidewall of the tire. I have 235/80-17 Generals that are at 45psi.
Wes Siler
Wes
Bozeman, MT
WesSiler.com
2021 Ford Ranger XLT FX4, 2020 Toyota Land Cruiser
Writer
That's usually the max pressure, and running that isn't a great idea unless your truck is loaded down to max capacity.
Remember that pressures vary by tire construction. A p metric tire will require less pressure than an LT or flotation tire, regardless of size.
Here's a good calculator, I'd encourage everyone here to start with its recommended pressure, then adjust up or down as you get a feel for it.
https://tiresize.com/pressure-calculator/
And yes, 15-18 PSI is appropriate off-road. Go lower on sand or deep snow, but don't go lower if you're going to hit rocks.
RRTruuck
Utah
2021 Ranger Lariat
When I drove my truck off the lot, the dealer had inflated the oem Hankook Dynapros to 46psi. I wondered why I could feel every single pebble on the road until I got home and realized what they'd done, smh :explode:
V1nnn
Az
Ford Ranger Tremor
Your pressures are way to high on the street. I run 30-32 on the road with my Patagonia MT’s and 15-20 on trails.
Factory door said 39 PSI for factory tire 270/70/17, my new tires 285/70/17 that why I thought 39-40 PSI should make sense, but I’m not professional, Justin a regular weekend warrior.
V1nnn
Az
Ford Ranger Tremor
This is what it look
FordFreak
2020 Lariat FX4 Ranger, 2022 Sonata Limited
Depends on the tires
RedRocker
N. Texas
2021 Tremor, 2006 LJ Rubicon, 2013 Ram 3500 dually
Retired Machinist/Fabricator
Mine doesn't have a door sticker, thought that was kind of odd.
