What speakers is everyone upgrading to?
cfhgarza
Ohio
2020 Magnetic XLT 301A
Press and weld set-up
Do you know if we need a mounting bracket? I only ask because stage 3s kit comes with one so you don't have to do any extra drilling! But on crutchfield it says it fits our trucks so does that mean the holes line up? Lol
Im not sure what speakers you're looking at but the ones I was came with the ring. If you chat with them they super knowledgeable.
Lost19Ranger
Lost19Ranger
2019 Ford Ranger XLT FX4 PKG
Sales
Ok it looks like I will just chat with them and make sure once I decide because it looks like they make it easy! Thanks for the help!
Living The Dream
Just adding a sub and sub amp did wonders to my non-B&O system. It absolutely jams on 17-21 with my JL 8". I listen to EVERYTHING too! From Bob Marley, old school Tone Loc to new school Country.
Were you able to remove the artificial engine noise?
I had an aftermarket sub in my truck but ended up removing it because the fake engine noise grated on my very being.
Robisten8
Central Texas
2020 Ranger XLT Sport 4WD, 2021 Bronco Sport
I've read about others having problems with this and noticed they weren't using a higher quality line output converter for their installs. The problem doesn't exist with my setup.
RANGER_MARC
MARC
Delaware USA
FORD RANGER LARIAT 2019
TEACH
No upgrade needed.
One more reason the Lariot is a great purchase :thumbsup:
I totally agree! This is one of the few vehicles I have owned that I do not need to spend extra money upgrading the sound system!
Living The Dream
Which one did you use?
Lost19Ranger
Lost19Ranger
Sales
No upgrade needed.
For some it may have been a great purchase but for someone like me not wanting the lariat grill not wanting the digital tach that is used in the fusion I traded in as well as a couple of other things. So yes for you it was a great purchase but for others not so much.
CashSeeAO
Central New Mexico
2023 Ranger XLT Super Crew
Semi-retired engineer
Woodn88s
Don
Louisville
2020 Ford Ranger xlt
Lost19Ranger
Lost19Ranger
Sales
Langwilliams
Langley
Lorain, Ohio
Did you utilize the tweeters also? If so how was the install on those?
I'm curious about this too....do you use the factory wire for the tweeters or run wires using the supplied cross over...does ford split the signal in the factory wiring?
CashSeeAO
Central New Mexico
I used the Rockford Fosgate tweeters. They are superior over stock. They fit in the stock housing, but required a little coaxing. Just be patient and take your time. I did mar the outside of the first tweeter because I was forcing it. Once in, no one would see the scratch. The second one went in much easier. Crutchfield included instruction on how to remove the stock tweeters, which was not too bad.
Got any pictures to share? Where did you install the amp?
CashSeeAO
Central New Mexico
Ford does not split the tweeter and woofer wiring from the head unit on the XLT system. The HU sends the full range signal to the front woofers, and the factory tweeters tap off the woofers in a parallel connection. These RF front components have the crossovers built into the woofer housing so I did not have to find a place for the crossovers. That was the best part about these RF components. Once the woofers are in, i used separate (RF provided) wires to connect the tweeters to the woofers. Install was super straightforward.
