I would love to see a midsize EV truck, but I don't think it will happen soon.Sounds like the perfect use case for an EV
Yup. Don't think Ford has any interest in mid size trucks and after the Lightning failed to launch.....I would love to see a midsize EV truck, but I don't think it will happen soon.
The Slate looks kinda promising, but RWD only is all that's offered initially.
There are rumors of an AWD version soon. That would certainly pique my interest.
Oil sample for the 1000 mile test drive oil came back today at 6.1% . So now we’ll see what things look like after a few hundred miles on the new HPFPGot my truck back today. They replaced the HPFP under my 5/60 powertrain warranty. And a fresh oil and filter change. Will have to monitor the progress to see if that has taken care of the problem. The repair entailed removing the intake manifold so I asked if the tech could grab a couple of pics of my intake ports/valves to see what they’re looking like at 26K. He obliged so I’ve attached them. He also grabbed an oil sample of the 1000 mile test drive oil. They were looking at elevated level on the dipstick. I want to see what that oil tests at. The previous oil only had about 500 mile on it and it was at 8%. Dropped the sample off this afternoon so I should know next week sometime. I’m really fortunate to have a good dealer that works with me. Here’s hoping that this resolves the issue.
Curious for your thoughts on the intake images.
Nice!!!!Update: 1800 miles on new HPFP and oil level hasn’t budged. Looks like it’s resolved. So if you’re seeing elevated levels on the dipstick and high percentage fuel levels in an oil sample the HPFP is definitely a possible culprit. It was covered under the 5/60 warranty.
Fascinating!Update: 1800 miles on new HPFP and oil level hasn’t budged. Looks like it’s resolved. So if you’re seeing elevated levels on the dipstick and high percentage fuel levels in an oil sample the HPFP is definitely a possible culprit. It was covered under the 5/60 warranty.
You have to also remove the intake manifold to replace the fuel line because the connection to the fuel rail is under the intake manifold. The steps for removing the intake manifold are intriguing.Fascinating!
On RockAuto there's a Bosch for $150 and a Motorcraft for $250
https://www.rockauto.com/en/catalog...urbocharged,3443244,fuel+&+air,fuel+pump,6256
https://www.ford.com/product/fuel-p...vBxYWigLTWudUR4CGQUuVtCnGQZXSTFdbD2NBuvH_43uA
https://ford.oempartsonline.com/oem-parts/ford-high-pressure-line-k2gz9j323b
https://ford.oempartsonline.com/oem-parts/ford-bolt-w720040s442
Haynes says to discard the fuel pump line and use a new one, and use new bolts -- no big deal
Haynes says to turn the crank shaft to align the cam lobe for installing the new HP fuel pump and has lot of warnings about specific order to tighten the fuel pump bolts -- this job suddenly got realI might still go for it.
