OFC Ranger
Jack
ZR2
Finally got around to moving and setting up my switch box for the dash tray. It was installed near the hood release by my left leg but I learned this was an awkward place to reach down and toggle the switches.
Dahveed
Central Kansas
Pharmacy Consultant
Installed some Auxito LED 194s in my license plate and side marker lights. Also installed the Auxito 3000k yellow fog bulbs as well. We'll see how they look tonight. I left them clocked at the 9/3 position. Is that what others have done?
I'm waiting on shipping for a set of Lariat headlights, an LED CHMSL from an F-150, and a set of Auxito amber LED front turn signals.. Wanted to go full LED.
port43
Detroit Suburb
childrescuecoalition.org
Secret agent, man
Drove in the rain today. Then I pushed the TM button and got this message. The system would not work until after I turned the truck off and restated. Working now. Anyone else get this message?
Do you have a tune loaded? I saw that repeatedly when I was setting mine up.
port43
Detroit Suburb
Secret agent, man
cfhgarza
Ohio
2020 Magnetic XLT 301A
Press and weld set-up
What year F-150 is the CHMSL from? Interested in see how it looks installed
HTX1811
HC
Houston, TX
19 Ranger STX 4x4,16 Audi A7
I do and have for a while. First time it has come on was today. I have used it numerous times with the tune installed.
Dahveed
Central Kansas
Pharmacy Consultant
I think this one specifically is from an ‘18. But the size is the same from ‘15-20, I believe.
quangdog
Kimball
Meridian, Idaho
www.youtube.com
2019 Ranger Lariat FX4
I tried (and failed) to check the trans fluid level. The space is just too dang tight, and the catalytic converter is too dang hot. Cut one finger, and almost burned my arm. Could handle the heat with my welding gloves on, but then could not wedge my arm up there well enough to release the torque on the plug.
I was only even trying this because I've driven other fords with this same transmission that shift absolutely buttery-smooth, and I can feel every gear change in mine. I suspect either the fluid is a tad low (others on this forum have reported them underfilled from the factory) or I need a TSB performed. I have not pestered the dealer with any service stuff like this yet, but it may be time.
JaysOnTheEDGE
Jay
Office Equipment Technician
Could have been a glitch I came up on someone little quick and my collision avoidance alert blared for about a second then it said collision avoidance fault , collision avoidance not available. I shut the truck off at a stop light and turned it back on and all was normal.
Ronbo
Ron
FL, CT, TX
2019 Ford Ranger XLT FX4+
Added;
LED strip lights over headlights
Switchback turn signal bulbs
LED side marker lights
