LowKeyTremor
Kyle
Northern Cali
2022 Ranger Tremor Lariat
Business Owner/Partner & IT
SD4160
Scott
NJ
2022 White Lariat FX4
Electrical test technician
I finally adjusted my tire size with forescan. I upsized my tires by about 7% over 2 years ago, lol.
Nice! What size are you running and what did you change in forscan? I'm dragging my feet on this currently.
SD4160
Scott
NJ
Just received and installed my stubby antenna from builtright.
Also kept working on getting my bed panels setup. Got the last bit of SS hardware needed from HD after having to get slightly creative (not really) with mounting the DC/DC charger since none of the mounting lined up properly. It was quick and dirty with some 1" aluminum flatstock, but it did the trick.
Anyone agree/disagree with installing grommets to cushion the DC/DC charger? Unlike the inverter, it's mounting points are plastic and I was concerned with it cracking if firmly bolted to the panels. Maybe I'm over thinking it? Grommets weren't my first choice, but all HD had. Might look into rubber spacers.
Just need to install the battery monitor (arriving tomorrow) and make up the bed lighting wire harnesses and it should be useable, even if temporary for now.
JACKSMYDOG
Jay
Ontario
2020 Ranger Lariat FX4 Black
The factory setting was 2365mm for 265/60-18 but Tiresize.com lists 2433mm for that size.
I'm on 285/70-17 now which Tiresize.com lists at 2609mm so I set it to 2530mm which is the same 3% drop as 2365mm represents.
I didn't test it yet because I had a few glasses of wine already, just sat in the garage playing with it. I'll take it out in the moring and bring the laptop, making as many adjustments as I need to get it in sync with GPS speedometer app. I'll update after I zero it in.
Colo_Ranger
2021 Ford Ranger XLT FX4
This was quite the process for me too, when I upgraded sizes. I’m all my 3 tire sizes after factory, none of them have been what the calculator says they should be.
BigRedDog
Cam
STL
2020 Ford Ranger Lariat FX4
CPA
Installed a sequential LED mirror turn signals and matching marker lights. Quick and easy and a nice visual upgrade for ~$75:
Synfulz
Richard
Philippines
2020 Ranger FX4 Diesel :)
Retired Powerplant Operator
Got home from our trip after 9 days, plus 5 days previously not starting. Even though I was sick I went and started and let idle for about 15 minutes.
Also had a typhoon blow through, even it was in my carport it's a mess. A another day task.
87TxAg
Houston
21 Bronco Wildtrack, 23 Ranger Lariat Tremor
Forgot to post the other day, but used the Ranger to grab some late night sweets. The Blue Bell Dr Pepper ice cream was gross?
Agreed. Its almost like you can taste the carbonation of the DP. Sorry Blue Bell, you missed on this one!
SD4160
Scott
NJ
2460mm is my final setting for LT285/70-17 D-Rated Duratrac with 40,000km or 25,000m on them.
Wow. So it really is just guess and check. Good to know. Soon enough I'll get forscan download on my laptop so I can make a few tweaks. Actually may go do that roght now. Thanks for reporting back.
NeilP
Neil
Spearfish, South Dakota
RETIRED!
Spent 5 minutes removing the OEM puddle lamps and replaced them with Bright TRAX lamps. The Bright TRAX lamps are incredible.
