Tuning for aftermarket wheels
V1KT3R
Bridge City, Texas
2019 Ford Ranger XLT, 1990 Ford Bronco Eddie Bauer
I have a lift with over-sized tires which is throwing off my speedometer, odometer, and fuel economy calculations. Whats the easiest/best tuner to correct this issue?
PNW_Ranger87
Erik
Renton, WA
2019 Ranger XLT 4X4
Parts Specialist
I don't have too much knowledge on what Forscan can do with the Ranger but I believe that's going to be your best bet. As far as I know the only option with Forscan is that you can toggle between factory tire sizes. That's how it was with the Focus I had. I don't believe you can enter an OD and just have it calibrate to that size. I'm hoping someone weighs in on this some more because I definitely plan on going up in tire size as well and I'm pretty picky about my odometer/speedometer. :sunglasses:
FULLSCALE
Adam
Ontario, Canada
I thought I read a post saying the dealer can adjust for tire sizes?
I seem to think I’ve heard that too. Maybe they change it in a similar way to how does?
V1KT3R
V1KT3R
Bridge City, Texas
I have reached out to three different dealers and all told me they could get it close but not on point. It's a little annoying since I had the dealership install the lift, wheels and tires.
jhndeergrn
East Coast
Ranger
My dealer couldn’t do it either. I downloaded my tune from Livernois and they are still working on it as well. The Livernois tech said the only way to do it is through Forscan or with Hypertech’s calibration device for $229. I might find a used laptop for that much just to use for forscan.
http://www.hypertech-inc.com/vehicle-results.aspx?AAIAID=511099
j0shm1lls
Josh
SoCal, USA
www.youtube.com
2016 Focus RS, 2019 Ranger SCrew Lariat FX4 Sport
The dealers can only swap between the wheel sizes that are available from the factory. They can't enter a custom size. If you want to correct your speedo, you'll have to do it through an aftermarket tuner or Forscan.
jpboats
2019 Ford Ranger Lariat , Blue
jpboats
I have used there units on F150,s and they worked great
Ryan...
Ryan
2007 Range Rover Sport
+1 for Hypertech. Used one on my F150 w/35's and I got the speedo dead on at every speed from 5-90mph, using a GPS to verify speed.
FULLSCALE
Adam
Ontario, Canada
Is there any reason to use Hypertech over Forscan or the other way around? Any downside to one or the other?
Hack_Actual
Justin
Oklahoma
2019 Ford Ranger Lariat FX4
I have the Hypertech because the shop the dealer uses that installed my lift and wheels and throws it into their “package.” I can choose any wheel size I want and using a speedometer app on my phone, it is within 2MPH at 70MPH.
FULLSCALE
Adam
Ontario, Canada
I have the Hypertech because the shop the dealer uses that installed my lift and wheels throws it into their “package.” I can choose any wheel size I want and using a speedometer app on my phone, it is within 2MPH at 70MPH.
Thanks. I’m thinking the Forscan way may be more accurate than that from what I’ve read.
