Tremor Mud Flaps
fergthulhu
Sean
Colorado, USA
'21 Ranger Tremor, '09 Toyota RAV4
Senior Solutions Architect
Looks great. Mine should be in today, I wasn't going to get them since I got new tires and they seem to be doing a good job of not throwing rocks, but I figured why not. Still good insurance if I feel like flying down a gravel road.
Oh nice..what tires did you end up with? I won't replace these until they need it, but it'd be good to know. I'm hoping these do a pretty good job so I can take the side steps off; before they were the only thing saving my paint.
Madesicc88
V
Idaho
2021 Ranger Tremor
Electrician
I went a bit more aggressive than I originally planned and did the Yokohama Geolandar g003 MTs. I put close to 800miles of interstate and mountain passes on them over the week and they performed great. They are E rated so a bit stiffer but I just run them a bit lower PSI and they have been fine.
Got my Mudflaps on today too, I went with the normal size and they fit and look great. Going to run them for a week or so and see how they protect before I take off the side steps.
Madesicc88
V
Idaho
2021 Ranger Tremor
Electrician
Went and put the flaps to use today, the new tires pick up significantly less rocks than before and hear a few hit the flaps. They did their job.
Danager
Dan
Alberta
2019 Edge
Manager
The video is pretty good. I needed a T25 for the screw on the bottom/underside of the front wheel lip moulding.
I also put in the top screw to begin with, allowing the flap to hang while I lined up the bottom one. Probably less of an issue on a lift, but on your back on the driveway, balancing a mud flap, a bolt, a washer, and two spacers wasn’t the easiest approach.
krane
md
Focus RS
Nice that rb's now are endorsed and include the proper equipment, what did you guys choose? Regular or XL ? ***edit*** reading back it looks like XL is the way to go. thanks guys!
SactoJim
Sacramento CA
2021 Ranger Tremor
Software Engineer
These are the XL. I think the fit is good, maybe a little larger than needed but the regular would be too small.
Madesicc88
V
Idaho
2021 Ranger Tremor
Electrician
I did the normal size on mine, I like the way they look
halligan1201
Byron, IL
2020 Ranger
Emergency Management
I am a new member and found out about the rockblokz on here fig I would share some pictures of the regular size flaps
How are they at fixing the Tremor rock throwing issue?
