TBR17
- Joined
- Jan 5, 2021
- Threads
- 15
- Messages
- 934
- Reaction score
- 2,523
- Location
- Murphy North Carolina
- Vehicle(s)
- '21 Ranger Tremor, '13 Vette Z16, '62 VW Beetle
- Thread starter
- #1
Anyone know what flaps fit a Tremor?
Thank you my friend. I foresee some snow in my future when I do a “Freedom Relocation”, so that’s definitely something else I need to consider ?@Secousse If you're going to be doing a lot of off roading I wouldn't get mud flaps. Your friends are correct they're usually the first thing to go as they get hung up on rocks or fallen trees. I had them on one of my F150's back east and they broke the first time off roading. I never added them to any other truck since and I've owned 9 of them. Not an issue for you being in CA but they can get hung up on snowbanks too and when cold they break even easier unless they're rubber.
It is, but the people buying them think it's a whole different truck.I haven't read up a lot on the Tremor but isn't this just an options package on a regular Ranger? If so wouldn't the body panels be the same and the Ranger mud flaps would fit?
Lol I did too when I first started seeing the comments on them. Then I went to Fords site and realized it's just an options package. I didn't think they'd retool the assembly line for the Tremor when the next Gen should be out in a couple years.It is, but the people buying them think it's a whole different truck.
Different and wider fender flares to accommodate the bigger wider tires. So no regular ranger mudflaps will likely not work with a Tremor.It is, but the people buying them think it's a whole different truck.
They are simply wider. And not by much. They attach the same way as the non Tremor flares. Any flaps for a Ranger should fit.Different and wider fender flares to accommodate the bigger wider tires. So no regular ranger mudflaps will not work with a Tremor.
Most flaps leave a bit of inward/outward adjustability.Won't be wide enough. Several have tried and said they don't work.
I run these on my truck in the XL size, they won't be damaged off road either they're a really flexible rubber/plastic material. If you rip one of these off, you likely smashed whatever body panel it was attached to anyway.Rokblokzs make a xl set that are wider and longer for lift kits and off road tires
I'm betting they would work well.
https://rokblokz.com/products/ford-ranger-2019-mud-flaps
