trailer not connected,yet connected
Wolfman00
maryland
2020 fx4
yesterday i went to hook up the car trailer, all lights work, brakes worked… but nothing came up on the dash about the trailer being connected as it usually does.
a few things- trailer plug looks beat. could be that.
bad ground cause it?
last time i used the trailer i had to jiggle the plug and it worked.
worked fine with the camper last time i used it so i dont think its the truck.
ideas where to start looking?
trying another trailer today after work too.
myothercarizahearse
Cleveland, Ohio
Unretired
I vote bad ground. every time I tow my boat I need to mess with the ground connection on the trailer. it's usually clean with no rust but it just doesn't like working most of the time
myothercarizahearse
Cleveland, Ohio
Unretired
do you have clean contacts in the plugs?
Adventure Ranger
Saskatchewan, Canada
2020 Ford Ranger Lariate Crew Cab FX4 Sport
Heavy Equipment / Truck shop Foreman
I had this issue and found the gel type insulation in the plug itself was deteriorating and coming out, this was actually allowing the back of the terminals to contact each other and cause the faults. Dealer installed a new trailer plug under warranty - no more problem.
Wolfman00
maryland
2020 fx4
tried a different trailer. same crap.
all started when they changed my battery. is there something that could have been turned off in the process?
im pretty pissed off at the bullshit this truck has.
Wolfman00
maryland
2020 fx4
you did? your trailer wouldnt show connected or anything either?
i tried two trailers and same thing. im pretty frustrated with this truck at this point.
Wolfman00
maryland
2020 fx4
so my battery was replaced a few weeke ago, i wonder if something got disabled?
Wolfman00
maryland
2020 fx4
went to dealer and they confirmed trailer connects and works, but the trailer does not connect in the software. so it goes in on friday.
Wolfman00
maryland
2020 fx4
trailer module had a short. they think it happened when they changed the battery. pick it up tomorrow
