Tires Size Question: 255/70/r17
derekw24
NC
2020 Ford Ranger XLT Sport 4x4
Accounting
Hello!
I am new to the Ranger Forum, recently got my 2020 XLT and I am thinking about upgrading the tires soon. I have done quite a bit of reading on this forum and havent seen too many people go with the above mentioned tire size.
My stock size is 255/65/r17. I know going to 70 isnt a huge difference but I just want something slightly taller that fills out the wheel wells. I am assuming going with 255/70/r17 will have no issues in terms of rubbing, but hoping I can get some feedback and confirmation with this change. I do not have a lift, just stock suspension and dont have plans to add a lift for a little while because $$$ (hoping I wont need to add spacers or do anything with the offset of the wheel).
One other question - if I get a taller tire, will that affect how much I am able to tow or have in the bed of the truck at all because of the taller tire? Never owned a truck before so just curious.
Thanks in advance for the help!
OrangeStreak
New Mexico
Hello!
This link will give you the tire size specs for the Ranger...
https://4wheeldriveguide.com/largest-tires-on-a-ford-ranger-biggest-tires-no-lift/
GreyAreaRanger
Houston
2019 Ford Ranger XLT
Surgical Nurse
Your towing/payload may be affected a little bit but is dependent on the weight of the tires. I would expect the larger tires to weigh a little more but chances are that the combined weight is probably a negligible amount. Let's say each tire weigh 10 lbs more for a total of 40 lbs of towing/payload lost if my understanding is correct. More importantly would be how much things like your speedometer is affected be the increase in tire size
derekw24
derekw24
NC
Accounting
Thats a good point.. I have looked around and sounds like Id need to adjust the tire size in Forscan.. do you know much about that/do you have experience in getting larger tires?
GreyAreaRanger
Houston
Surgical Nurse
I have never used forscan before so I’m afraid I’m not much help with that but I’m certain larger tires is such a common mod that someone will be able to help you get started. There is a stickie in the electronics sections pertaining to forscan and that’s where I would make my start.
EJH
Ed
Subarus, 2021 Ranger
https://forscan.org/forum/viewtopic.php?t=15994
That said, I was unable to go larger than a certain circumference (as the thread mentions), but I was able to get the value large/close enough that my speedometer matches the Waze GPS speed now.
5thranger
Gary
kansas
2020 Lariat Ranger Rapid Red
The tire shop should be able to do the calibration to correct speedometer, when I put taller tires on my F150 they did it after they mounted tires back on truck.
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
How would they do that? Do they have a tool that they go in and do it through obd port? Can any tire shop theoretically be able to do such a thing?
derekw24
derekw24
NC
Accounting
Was it a local shop? Ive called around to a few places and they just refer me to the dealer (which I might see if they can help with recalibration).
5thranger
Gary
kansas
Yes, it was a local tire shop. One of the techs had a scanner and did it. I got the impression it was what they used to calibrate the TPMS sensors with as well.
Grandaccess
Binghamton, N.Y
Computer Consultant
I always thought 265 was stock?
I have much larger tires and I do not notice much of a difference at all in handling, towing or MPG
in fact on bad days I get 20mpg but on average I get 22mpg, and hauling some pretty big loads
I say go big or go home LOL
EJH
Ed
Some will, some won't. Discount will not.
Waxthis
Eric
2020 Ranger XLT FX4
Controls Tech
I went from stock 265/65/17 to 255/70/17. "Micheline Defender LTX M/S". Negligible difference on speedometer, mileage did improve a little, 30k on the tires and they still look new. Awesome tire! I do have a 2" lift in the front, however you will have no issues.
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
255/70’s aren’t enough different enough to bother adjusting in Forscan. 265/70’s fit stock and were a factory optional size in 2019-2020 and won’t affect towing capacity. I have 265’s and did adjust in Forscan, 2400mm was perfect.
