Tire size versus RPM's
NotBudule2
Robert
21 Ranger
Right now , in Sport mode , cruising at 40 MPH is equal to exactly 2500 RPM's , if i jump up to 33's (or just a tad smaller) what do you think the RPM's will drop down to ? Or will it even be noticeable?
PltFX4
Richard
Minneapolis, MN
2019 Ranger Lariat FX4
Speed versus RPM Calculator
OK, Sport Mode in what gear??
MPH by gear
My SummersOEM 18"32.7"
RPM: 2000​
Gear Ratio
275x55R20​
265/60R18​
285/70R17​
First​
4.696​
10.84​
10.33​
11.11​
Second​
2.985​
17.05​
16.25​
17.47​
Third​
2.146​
23.71​
22.60​
24.31​
Fourth​
1.769​
28.77​
27.41​
29.49​
Fifth​
1.520​
33.48​
31.90​
34.32​
Sixth​
1.275​
39.91​
38.03​
40.91​
Seventh​
1.010​
50.38​
48.01​
51.65​
Eighth​
0.854​
59.59​
56.78​
61.08​
Ninth​
0.689​
73.85​
70.38​
75.71​
Tenth​
0.636​
80.01​
76.25​
82.02​
Reverse​
4.866​
10.46​
9.97​
10.72​
NotBudule2
NotBudule2
Robert
21 Ranger
MPH by gear
RPM: 2000​
Gear Ratio
275x55R20​
265/60R18​
285/70R17​
First​
4.696​
10.84​
10.33​
11.11​
Second​
2.985​
17.05​
16.25​
17.47​
Third​
2.146​
23.71​
22.60​
24.31​
Fourth​
1.769​
28.77​
27.41​
29.49​
Fifth​
1.520​
33.48​
31.90​
34.32​
Sixth​
1.275​
39.91​
38.03​
40.91​
Seventh​
1.010​
50.38​
48.01​
51.65​
Eighth​
0.854​
59.59​
56.78​
61.08​
Ninth​
0.689​
73.85​
70.38​
75.71​
Tenth​
0.636​
80.01​
76.25​
82.02​
Reverse​
4.866​
10.46​
9.97​
10.72​
I didn't look at what gear 😳, but i will , thanks for the chart !
OCL
Mission Viejo, California
2021 Ford Ranger Tremor
If you have a standard FX4, you can get away with one size up in tire size.
FX4=255/65/17
Tremor=265/70/17
The tire diameters are different. Tremor tires 1.5" taller. So your speedometer will be off. You have to use Forescan to recalibrate your speedo to the correct tire diameter so your transmission's shifting is correct. The Tremor tire size is the biggest you can go without interference with your front crash bars/rubbing.
The tire size difference seems small but it makes a huge difference in looks especially if you get wider wheels/wheel spacers.
You cannot put 33's without 2.5+ inch lift and front crash bar modifications.
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
The stock tires and speedo are slightly off verses gps from the factory. You might be able to upsize 1 size with no changes. Typical of most American manufacturers. Makes mpgs look better and shortens warranty by the maximum allowed variance in speedo accuracy by law.
NotBudule2
NotBudule2
Robert
21 Ranger
Im aware of the speedometer issues and such , my question is , what will my new 40 MPH crusing RPM's be after upsizeing. My current RPM's are 2500 and I would be happy er 😊 if they dropped to around 2000...
Superspirit
earth
22 ranger
I have 33's on mine. If you tell me what gear you are in at 40mph to get 2500, I'll go drive mine at 40 in the same gear and record the rpm for you. Have to know the gear.
Dereku
Derek
Chicagoland Area
2021 Ford Ranger
Project Manager
Thats a lot of tire. I had 46s was back went. It was like a super over drive.
NotBudule2
NotBudule2
Robert
21 Ranger
Mine likes 5th to be at 2500 at 40 in Sport Mode
I think in Tow it drops to about 1600 and hits 7th gear
Drive is horribly low rpms and I never use it...
Superspirit
earth
22 ranger
Sport mode locked in 5th with 33's I got right at 2300 maybe a few rpm over. But I will tell you fuel mileage went down with the heavier tires.
NotBudule2
NotBudule2
Robert
21 Ranger
So only a couple hundred lower, nothing dramatic, that's good 👍... im aware the mpg's will suffer, but gas ⛽ is pretty cheap nowadays, so no biggie there , Im still buying premium just to burn brush and wash out stain brushes and such, its a good cheap weed killer too, I keep a gallon or so in the sprayer at all times...
Superspirit
earth
22 ranger
Don't know where you are, but I'll never refer to $5 gal gas cheap. I remember $0.22 gallon.
I can remember riding my mini bike to the local fuel station and getting a full tank of gas and a pack of cigarettes for $.50
