Colo_Ranger
Bring My WalletJust Empty Every Pocket
A TSB should have nothing to do with your ESP. Don't let them charge you a deductible.Update: dealer called after lunch...now they say its the Slip Joint TSB and pinion. All covered under Ford ESP. Looks like several business days on parts. I'll be making use of a loaner starting Monday.
Good to know. I’ll remember that and check it once they get it done.A TSB should have nothing to do with your ESP. Don't let them charge you a deductible.
Sadly this is one that only Aussies would get.A TSB should have nothing to do with your ESP. Don't let them charge you a deductible.
It’s technically not a redesign. It’s the driveshaft that’s in the Tremors. Uses a Rzeppa joint at the differential instead of a ujoint.Update: picked it up today. They have redesigned the driveshaft assembly. They replaced the entire assembly and rear flange under warranty and listed the TSB#. I attached the parts list. No thunking or shuddering as of now.
Now at my tire shop getting new shoes. Will update that thread with pics in a while.![]()
