Gazmic
I would imagine that lithium, much like other metal fires (magnesium, titanium) can't be put out with water. I'm pretty sure water makes the fire worse!
I was reading some firefighting blog posts earlier and it talked about the gas that is put off by lithium battery fires, one of which is oxygen which is what makes them so difficult to put out...I would imagine that lithium, much like other metal fires (magnesium, titanium) can't be put out with water. I'm pretty sure water makes the fire worse!
Moore's law at work. Evolutionary change in progress. The technology wasn't changed, simply refined over time.Yup. lots of IF's for sure. But look at memory on your computer.
I remember switching out 4k to 8 k memory WOOHOO!!! It may
or may not work but I'd like an EV, just not now.
Mr Fusion is sold out! That sucks!!!!
Years ago we used a halon system in our main frame computer room and I know it's banned now but if the battery case could have a system like that it sure would be better then punching a hole in the battery. Guess a fire suppression system should be made a requirement for EV's like airbags.I also read about some new fire fighting tools for ev fires - one was essentially a spike you slide under the vehicle, it punctures the bottom of the battery and sprays water inside the battery packaging.
This tech could put out a battery fire in as little as 500 gallons.
Tomorrow from the office I'll post the links.
I saw that the other day. Only problem now is gas is rising again and soon enough it'll cost more to run an iCE than a EV. But don't worry once electric rates increase and they start paying the road taxes they're avoiding now the EV price per mile will shoot right back up there. ?0UCH!!!! Is PHEV still worth it?
https://www.theepochtimes.com/fuel-...n=ZeroHedge&src_src=partner&src_cmp=ZeroHedge
Getting back to excess water use to put out an EV in the desert. Yes.
Maybe they should get a truck with a crane & pool on the back & just pickup & drop in pool? ?
If a battery could take a full charge in 5 minutes then the tech would exist for it to recharge itself as it rolled down the highway. LOLYour absolutely right, the ICE was so much better. Now if EVs become 50% cheaper then ICE & can go 500 miles & full charge in 5 mins, what would you buy?
The power company here has had 3 rate increases within the last year. The latest one cost the company I work for an extra $44k per month. I wonder who ends up paying for thatI saw that the other day. Only problem now is gas is rising again and soon enough it'll cost more to run an iCE than a EV. But don't worry once electric rates increase and they start paying the road taxes they're avoiding now the EV price per mile will shoot right back up there. ?
Time for a war story! You don't realize how special a time is until you have perspective. You are too deep in the trees to see the forest. It has a little ( just a little ) to do with the EV susceptability to fire.I would imagine that lithium, much like other metal fires (magnesium, titanium) can't be put out with water. I'm pretty sure water makes the fire worse!
I wish I saved it but I did read an article a while back saying they're working on this. It'll be similar to a pull off access road on the highway and you'll be able to fast charge and get right back on the highway without ever stopping. But there's a huge cost in all of this and someone's going to pay for it.If a battery could take a full charge in 5 minutes then the tech would exist for it to recharge itself as it rolled down the highway. LOL
That would be an impressive feat of technology! Think about the power required to do this on a massive scale.I wish I saved it but I did read an article a while back saying they're working on this. It'll be similar to a pull off access road on the highway and you'll be able to fast charge and get right back on the highway without ever stopping. But there's a huge cost in all of this and someone's going to pay for it.
I found it. I'm not sure if it's the same article but it looks like it is. Yes it'll be very impressive if they can do this across the country and still keep in reasonably priced.That would be an impressive feat of technology! Think about the power required to do this on a massive scale.
Next spring, the nation’s first mile of public road that can charge electric vehicles as they drive over it will go online in Detroit.
A joint venture between the Michigan Department of Transportation (MDOT) and Israeli mobility startup Electreon, the road is the centerpiece of a $5.7 million program to study how charging roads in dense urban environments affect everyday life.
The technology is the same used to wirelessly charge a smartphone—on a much larger scale. A box connects magnetic coils embedded into asphalt to the power grid, and those coils then emit a magnetic field that is picked up by a receiver mounted to an EV’s chassis. The road isn’t meant to bring an EV back from empty: It charges at 20 kilowatts, roughly the same consumption rate an EV uses at highway speeds. The receiver can be installed on the assembly line or as an aftermarket accessory, and will work both in motion and while the vehicle is parked.
If 1/10 of the tech I read in Popular Mechanics as a kid had come to fruition we would be living on Mars driving fusion powered Rangers right nowI wish I saved it but I did read an article a while back saying they're working on this. It'll be similar to a pull off access road on the highway and you'll be able to fast charge and get right back on the highway without ever stopping. But there's a huge cost in all of this and someone's going to pay for it.
