Terrain management upgrade?
daczone
2020 Ranger
my ranger is European model with different four-wheel drive switch selector..if I make these changes I will be able to have the terrain management?it is necessary to replace a switch selector?
Thank you?
I tried this on mine this morning... Still no go.
jcw001
JC
Philly
2022 Ranger
I see 2 different part #'s in this thread? The truck is a 22 XLT 302a non FX4.
On Fordparts, both have the same picture and description and both have a warning that the part does not fit the truck (but I am guessing this is not the case.)
Which of these two am I supposed to order?
dmeyer302
Daniel
Carthage, MO
2016 Odyssey, 2021 F-150
Mechanical Engineer
Same part, -AD is a newer revision than the -AB. Probably a minor change. If you have the choice go with the latest.
jcw001
JC
Philly
2022 Ranger
Thanks.
In Forscan, I understand from vids that I had to enable in the IPC Selectable Drive Mode, which I did.
However, I also saw two other listings: Terrain Management System which was set to disabled as well as Terrain Management System Type that was also disabled. Do those have to stay disabled?
This is a 2022 Ranger.
