speaker upgrade
Sign1941
Maine
2020 XLT/FX4
I went with the Focal Integration IS Ford 165 both front and rears, not cheap, but worth every penny and couldn't be happier. Install was simple since its plug and play with existing speaker plugs and mounts. You will lose a bit of db but still plenty of power from the stock HU to drive them at high volumes.
If I had to do it over again after hearing the amount of mid bass they put out, cancelling the need for a small under seat sub, I might have gone with the Focal Flax Evo. Slightly less sensitivity at 2.83vdc (91.5 vs 91.7) but more range. But for the amount of time I'm in the vehicle, and what I listen to, it would be a tough choice to spend the extra money.
So the Focal Inside IS FORD 165 also fit the rear door? They don't say they fit the rears on the crutchfield site...thanks for clarifying.
JDowns
Coeur D'Alene
2021 Ranger XLT Tremor
I used these for the fronts.
And these for the rears.
The rears are the coax version and have a thicker front facing. They come with a foam ring for the front so they snug to the door panel.
Do not bother with rear inserts (baffles) for the front doors. The window will hit. You can use baffles for the rears as there is room. I just used a patch of Hushmats behind each speaker stuck to the doors.
FoD
Terry
Out There
Retired & Grandparenting 🤣
I installed Kicker's from Crutchfield - 4 doors and tweeters, they sent instructions for lame-o's and all the necessary pieces. Takes maybe an hour if you've not done these things before, less if you have. Good stuff.:like:
kieefer
keith
Just a tip, if you’re tearing door panels off it would be a good idea to add some sound insulation matt while you’re there.
Dr3wDrop
Andrew
OHIO
2021 Lariat Tremor
I think this little guy will fit in the back pocket where the B&O sub is/would be located. This would allow you to crank up the base on the nano sub unit and lower the Synch system to the door speakers.
jflogerzi
Moreno Valley, CA
No link :)
OrlandoJay23
Jayson
Orlando, Florida
2023 Ford Ranger
GC
PowerBass is an option and cheaper that crch
