Taillight melted
Capt Jon
Jonathan
St Augustine, FL
While the fuse cannot measure current, it should blow when the current through it exceeds its rating. The problem is the wiring after the fuse may not be rated for the same current the fuse on the circuit is. Take for example a 20A fuse to 5 4A loads, the wiring to a single load on the circuit may only be rated for 5A (still 25% over the device's intended load) for its given gauge and length. But should that part malfunction in a way that it's drawing 15A, it will burn up the wire and still not blow the fuse.
Capt Jon
Jonathan
St Augustine, FL
True. Most electronics like the sensing components in the tail light are most likely not able to handle larger current loads that would not be enough to trip the fuse. Looking at where the damage is without being able to inspect the light I would suspect an internal component failure, not the lamp itself.
Stephen Abbene
Stephen Abbene
Stephen
South Bay
www.notion.so
2019 ford ranger fx4 xlt, 1988 ford ranger 4x4 xlt
Dropped it off today. I put my bike rack on it to drive it over because it has turn signals and brake lights and I didn't want to drive around with signals. The first thing they did was call me and try to blame the bike rack, that is plugged into the stock 4pin trailer plug. I do not have high confidence in this going well.
JimG_AZ
Phoenix, AZ
2021 Ranger XLT FX4
Wow! Good luck!
SigOris
Greenwood Maine
Retired DoD EE
Why I always run one way diodes when tapping factory systems.
Nothing is full proof, but that one step drops the probability a lot.
There’s a two way diode?????
Max Crafter
Max
Canada
Ranger
Its part of Fords customer service training, to seek, identify, and blame anything a customer has done that might get them out of paying warranty.
SigOris
Greenwood Maine
Retired DoD EE
I guess the technical term is diode blocker.
A diode can serve many purposes: rectifier, detector, isolator…..
an oversimplification is that a diode is to electricity what a check valve is to fluids
standing by to get flame sprayed by the EXACTOS
Fawnbuster
Indiana
Retired 34 years as LEO
Any signs of a mouse getting in there and chewing the wires?
Well there are anti-parallel diodes, but it incorporates two 'one-way' diodes.
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
That's all well and good, but do we yet know what actually happened here?
OFC Ranger
Jack
ZR2
Bro all I know is I put the dikfer thing on that doo-dad and it stops the zap zap from going dis way and dat.
DaveT
Scottsdale, AZ
2023 XLT Ranger Tremor
Exactly my question. We have dozens of people speculating and discussing the complex nature of this circuit (at least complex for most people) -- and we have still not heard what the dealer will or has done about fixing it. I seriously doubt that the OP will be able to fix it himself, (I certainly couldn't) or even understand half of the speculations here. Let's hear results from the dealer!
