Taillight melted
TJC
A diode can serve many purposes: rectifier, detector, isolator…..
an oversimplification is that a diode is to electricity what a check valve is to fluids
standing by to get flame sprayed by the EXACTOS
We used them (Diodes) 50 years ago as voltage dividers in our 1/12 scale GM EMD F9 A and B Locomotives... Those diodes where massive (2"+ diameter), we silver soldered 12V battery cables to them. Had them seated onto 1/8" thick x 3"x3" aluminum angle cut into 6" sections for heat sinks. We dropped the voltage in 3v increments. There was a .75v voltage drop across the diode. We had 6 forward and reverse speeds... Used very large relays to vary the number of diodes in the power chain...adding/dropping 4 at a time. Old school and inefficient, but we never had a failure in that area.
We had 4 braking speeds accomplished by progressively shunting the motors...
which were surplus WWII aircraft landing gear motors rewired to a max 24 volts.
A long time ago in a land far away....
Stephen Abbene
Stephen Abbene
Stephen
South Bay
www.notion.so
2019 ford ranger fx4 xlt, 1988 ford ranger 4x4 xlt
It’s still at the dealership waiting on parts. They last quoted me 5k for parts which seems insane. Dunno how the tail light costs almost 10% of what the truck did….
Does sound high for parts unless the BCM failed causing it and need to replace it too.
