Sync3 Issues
Ronbo
Ron
FL, CT, TX
2019 Ford Ranger XLT FX4+
I don’t understand. I updated it a few minutes ago and it gave me that number. Got back in my truck after reading your response and checked for updates again. Went through the update all over again but it’s still giving me the same number.
I had this same problem trying to get the Sync 23188 software updated and I found that I had to do a master reset first. After everything booted back up again, the 23188 update started by itself OTA (Over the Air). No USB was needed. Also, after I did the master reset, I was kicked out of the Ford Pass App and had to reset my password to get back in to that. Everything is updated now to Sync 23188, but I left the maps at NA 2-21. I use Waze and Google so the Nav update for me was not necessary.
samsd
Dan
2019 Ranger Lariat 4x4, 2024 Honda Odesey, 2024 Street Glide
Where are y’all finding that 3.4.23188 number? Just updated mine hoping to correct it but these are the only numbers I see.
When doing the shut off the truck start the truck thing after the update, appaerently it is very important to lock the door with the door open once you have shut the truck off. Lights flash, makes strange noises.
I also think the master reset clears out some memory that makes the update easier to perform.
GreeneSayle
Greene
Mississippi
2020 Ranger Lariat
Fuel Sales
Thanks. I haven’t been able to use my Ford Pass app for over a month. Maybe this will help.
GreeneSayle
Greene
Mississippi
2020 Ranger Lariat
Fuel Sales
When doing the shut off the truck start the truck thing after the update, appaerently it is very important to lock the door with the door open once you have shut the truck off. Lights flash, makes starnge noises.
Do you have the step by step process ?
samsd
Dan
samsd
Dan
Here is the Ford link for update, I mention the lock the door step because when I was on Ford chat the tech told me that was an important step even though it is not mentioned in the update instructions.
https://www.globalowneraem.ford.com...us/documents/sync/Update+Your+SYNC_WIN_v1.pdf
I have done the updates with the truck parked and the motor running, parked with power on and hooked to a charger motor not running and the last update I did while I was driving. All worked equally well.
GreeneSayle
Greene
Mississippi
2020 Ranger Lariat
Fuel Sales
Installed 3.4.23188 via USB today and it completely fixed all of my issues. Ford Pass works now. Nav stays on course now. On board WiFi works now. And it returns to the last media I was playing. None of that has been right for 8 months. Thanks to all of y’all that helped!
GreeneSayle
Greene
Mississippi
2020 Ranger Lariat
Fuel Sales
Sure wish I had a laptop to fix my connectivity issues. Sure not getting any help from my local Ford dealerships service departments. No one returns my calls or text.
Borrow one or buy the cheapest one Walmart has. It’s definitely worth it. My truck is so much better now.
samsd
Dan
Get the recommended USB stick, go to the library or a friend that has a computer, download the new Sync version on the stick and follow the instructions to upgrade your Sync system.
trdewa
Trent
West Michigan
2019 Ford Ranger FX4
Has anyone experienced this? It started about 3 weeks ago, whenever I shut my truck off and restart it the radio will default to an FM channel. Sometimes it will default to SiriusXM channel 0. If it’s on FM and I select SiriusXM as the audio source it goes to channel 0.
Sync is 3.4. 19 Lariat.
I'm having the same issue. Stereo on every time I start Ranger (XLT FX4).
Superspirit
earth
22 ranger
Similar problem I always listen to usb music, when I restart truck it defaults to fm radio. And the new update did not fix this!
