Sync 3 has lost it's mind...
Phantomfixer
Florida
2021 Ranger Lariat FX 4
I have a '21 Lariat FX4 which has so far been a great vehicle.However,the Ford Sync 3 system is a constant source of aggravation.Here's the latest...my Ford Pass app will not connect to my sync three system.My unit has lost the Connectivity option and it's just greyed out so consequently it will not allow access to my Ford Pass app.Also,my audio selection defaults to AM radio.I'm thinking these conditions are all related somehow.I've done the hard reset many times and I've trouble shot the condition with the folks from Ford and they tell me the app is fine but my system needs attention from the dealership.So,yesterday my dealership (which has always treated me well) had me bring the truck in and spent time installing the latest update which I had previously installed on my own, but it would never finish downloading.I needed my truck so I took it home and they asked me to bring it back for some more troubleshooting.Does anyone have a clue what might be going on here?Your help would be much appreciated
alcohenusa
Alan
CO
2020 Ranger Lariat 4x4
Is your modem serial number showing up in the ‘about’ section? If not, then either the system is confused or the modem could be bad. You can either pull the associated fuses or disconnect the battery for a short time to reset all the hardware. When the system comes back up, the serial number should be displayed and the connectivity restored. If this does not retore the connectivity, then you may have a bad modem.
If you disconnect the battery, you will have to reset the driver auto down/up feature.
RangerBill
PA
Fuse F9 (Telematics) in the under-dash fuse panel (BCM) feeds the modem.
Phantomfixer
Phantomfixer
Florida
The modem info does display
alcohenusa
Alan
CO
You might try the fuse/battery disconnect anyway to let the hardware reset. May be worth a shot to avoid going back to the dealer.
Phantomfixer
Phantomfixer
Florida
I'm not too keen on battery disconnects.I've seen that create other issues.I'm going to bring it back to the dealer since it is still under warranty.I was hoping to get some ideas from you guys just to get some knowledge in advance.Thx so much for your help
Scottopia
Scott
Mooresville, NC area
'19 Ranger Lariat FX4, '11 GMC Acadia, '03 HD VRod
Grand Sovereign Monarch of Scottopia
Sounds like it may be tied to the discussion in the thread below:
Sync 3 Issues
Problem really is annoying.
RangerBill
PA
F9 fuse under dash, no battery disconnects. Will reboot modem. Worth a try.
Nopalito
Richard
21 Cactus Grey XLT
Emergency Manager
Your APIM is probably bad. Make them test it to get an error code. I got mine replaced by the dealer since my APIM failed.
bRaptor
Ward
USA
2021 Ranger XLT tremor
Could be a bad modem. This was something I heavily researched with my explorer, but eventually the update fixed the problem.
