Snow Plow on a 2019 Ranger?
coolrunning
rockland
ford ranger 2023
I have a snow blower like this that mounts on my lawn tractor, and it is AWESOME!!! I don't have a cab, I just wear a hooded jacket, and always clear with the wind so it's not bad. My driveway is 110 feet, double wide. I run the full length, lift the head and reverse up the driveway, drop the head and go again. With hydro-static, and reverse mode engaged, I don't have to engage/disengage the blower each pass, I leave it running the whole time. Without turning 180 degrees each pass, it's fast and never face the wind. Even with a foot of snow, I get the whole driveway, walkways, detail work, widen the entrance, and clear the left side road shoulder for 50' (so less gets ploughed back in) in about 20-30 minutes.
That can work , but i was looking to something that i can attack on the truck and use on my parent driveway too.
Does the ranger come with front receiver? Or need to be installed?
JACKSMYDOG
Jay
Ontario
2020 Ranger Lariat FX4 Black
Nice - I was thinking of using my lawn tractor for that when I lived in NB but I moved here before it came to be. Do use use chains and weights Jay?
I use chains, but no weights. They can slip on a hard ice base, but not bad and as the snow gets cleared they catch and go again. My driveway is relatively flat, if you have to clear up hill, weights may be a good idea.
JACKSMYDOG
Jay
Ontario
No front receiver. Most ploughs I've used don't attach via receiver but a custom mounting bracket that attaches to the frame.
coolrunning
rockland
ford ranger 2023
No, they were all work vehicles. Google front plough manufacturers and check their websites for specifics.
But install front hitch void the warranty?
I have see that come with 2 front hooks , what are they for?
Those are tow/recovery hooks.
coolrunning
rockland
ford ranger 2023
:( so cant be removed for the hitch.
Im try to understand if is possible install some kind of plow without void the warranty or not.
There are some small plow for the ranger , but they need a front hitch
coolrunning
rockland
ford ranger 2023
They show how to install the front hitch , and doesnt look invasive , can it be installed without void the warranty? Seems something that can be installed and removed very easily ( plastic that he cut. Can just be removed and reinstalled )
Rob @RedlandRanger installed a front hitch so he can be more help with it.
LaBalbe
Ontario / part-time NC
2020 Ranger Lariat
You can remove those tow hooks to mount something else. I don't know about a plow, but mine had a previous owner for a year (he traded it in for a 150), and he'd replaced the tow hooks with a mount to carry a motorized scooter; part of it is still there.
Mine's on the left, and @DukeCanBuildit is on the right; he's got a beefier set of recovery shackles, which I'm guessing had to replace the stock hooks. All that to say, you can remove the tow hooks, but I can't speak to a plow rig specifically.
coolrunning
rockland
ford ranger 2023
Just what i needed to know , with the front hitch there is the small snowsport plower , that isnt the best but can work for my little driveway
Thanks a lot
Fawnbuster
Indiana
Retired 34 years as LEO
I made this one last winter, worked great, I have a straight drive so I just back out of the garage and shove it off the road across the street. I bought a 12v winch with a wireless remote so I can lift it up as needed buy I haven't rigged it up yet. I like the front mount hitch, a company out west makes a small plow that would work with it. Nice part about that is if you mount your winch on a receiver hitch you could move it to the front or back.
I installed the hitch made by our very own @Heavy Duty . I've been extremely pleased with it. The only thing I would change is to use his later revision that was offset and doesn't require the ACC sensor to be relocated. His hitch design is very stout and I've used it with my winch on a few occasions.
