small tip when a load is sagging your trucks rear
dokoroko
usa
ranger
I was hauling water and of course the rear was sagging meaning my led cutoff was blinding people. I turned off my headlights and only used fogs when cars were oncoming. Now i did do the bambi mode mod using forscan so i don't remember if you can activate fogs independently without it. turned out to be really useful. I might invest in some auxiliary SAE lights and wire them up to simply be "load lights" that i can angle better and not have to juggle any switches. But regardless using fogs only is something to think about if you're blinding people.
Danager
Dan
Alberta
2019 Edge
Manager
Sounds like you were overloaded.
I cannot say he was not overloaded, but I experience this issue with a few hundred lbs in the bed. I’ve checked the aim of the headlights unloaded and it’s fine and only seem to get flashed by oncoming low riders. With a few hundred lbs or more but still under max (loaded up to go tent camping), I really piss off oncoming traffic.
This year I plan to load up and adjust the height of the headlights. I’ll make a note for each side - “loaded turn right 4.5 turns” as an example.
MountainGoat
Missouri
2020 Ranger XLT Sport 4x4
That's a shame. Truck shouldn't do that if it's within capacity. (Or the headlights aren't adjusted properly from the factory.)
Davidjc
NW Louisiana
2021 Ranger Lariat Super Crew
Retired LEO
I get flashed pretty often unloaded, my low beams seem pretty high & the high beams light up the trees.
I had to lower my beams as soon as I bought my 21 lariat with leveling kit. High beams were coon hunting.
Canadian Ranger
New Brunswick Canada
I can't say my Rangers sags...but I can definitely say I feel the difference in acceleration between having an empty tank of gas and a full one. So I wouldn't imagine it takes much weight to see the difference in the headlight beam.
Grandaccess
Binghamton, N.Y
Computer Consultant
I would love to know what it weighed, I scrap, I have had 1200 Lbs in the Bed, thats over 1/2 Ton and I may have gone down 1/2 an inch, I have a lift so its not stock springs....
I did notice the ride was nicer.
Simple.....if your Ranger has a sagging rear due to a "load", just make a "dump" run !!!!
Just ask David....he and Soupie make "dump" runs often to clear it's "loads".....
KNI
Finland
Ranger Raptor 2021
Hmm.. I just adjust the front lights from the front light adjustment knob.
Guess that's ROW only.
Shanewdude
Shane
Canada
2022 Ranger Tremor
carpenter
I squat 1 and 1/4” with a full load of tools. Makes my headlights evil for others! Too bad Ford didn’t make the cut-off shields adjustable from the cab. Honda did this for the European EP3 projectors… they had a five-position switch.
I suspect the Tremor suspension has more travel, and the initial spring rate is fairly soft. I’m considering lowering the lights with a full load, then see how it effects the beam height when unloaded.
Grandaccess
Binghamton, N.Y
Computer Consultant
Update to Limits: LOL I got a good deal on 14 Telco equipment batteries (145AH) so if the sun dont shine on my panels for a week, its all good, and drove 300 miles to get them, Well they are 110 Lbs each, so the limit is Not a 3/4 Ton 14X110=1540 In The Bed! they are about two times the size and weight of a marine deep cycle, how do some guys crack their bed going to walmart?
I never doubted this truck once, no squat, no sway and rides like a dream at 75mph, has lots of power ( I was in (S) mode) and I got 17.8 MPG 12 banded against the wall and 2 banded against the tailgate
I even had a shit myself moment LOL Thick Fog I-81 around Cortland there was a Car dead in the middle of the interstate! no time to slow down that kind of weight "safely", you know what went through my head in a split second, if I turn hard Im gonna roll it because my center of gravity sitting high, if I hit him they will find parts of his car in Pennsylvania! Dam-it this truck handles great with 1540 lbs in the bed, not enough body roll to even scare my passenger LOL
all this time I just assumed since the rims are 6 lug it was at least good to 1/2 ton? I never looked in the manual so I have no idea what it was max?
