Shocks installing concern, question.
VegasRanger
Las Vegas
2021 STX Crew Cab 4x4
Damper Salesman
So I replaced my factory shocks today with some Rough Country N3 shocks. My concern is that the metal ring around the top mounting location is pressed up against the trucks mounting bracket. This is me using the required torque specs. I’ve never seen shocks install like this, with that ring being pressed up against the brackets like that before. I haven’t had a chance to test drive it yet, so I can’t confirm anything yet.
Do you guys think this will be an issue?
GitRDone
Andrew
Orlando Fl
2020 XLT
Real estate management
Shocks installed upside down?
Stage3Motorsports
Diamond Sponsor
Joel
Phoenix Arizona
2019 Ford Ranger 4x4 XLT CrewCab
Sales Specialist
From their lift kit instruction, step 12 has you install with a washer, likely to keep that from happening, not sure if the shocks came with the washer, but looks like the lift kit does.
Stick a washer in their and youll be good.
VegasRanger
VegasRanger
Las Vegas
Damper Salesman
Thank you! Not a bad idea. Mine did not come with a washer or instructions lol.. that’s rough country for ya. :)
