Resonator Delete
Doc
Doc
Live oak fla
U just can't get an 8 cyl w/headers sound out of a 4 banger especially running a turbo. Yea doc, I'm 1 of those (67 yr) old guys. Hahaha!
Yup, you can’t make a sports car Inline four cylinder sound like a v/8....
Regards
drmoffitt
Dustin
Hays, KS
2019 Ford Ranger Lariat
Physician
Well that sucks. Makes you wonder why they had a resonator in the first place. At least it didn't make anything worse.
Hmmm, now what do we do? I think you're right, probably have to try a replacement muffler. Time to research a small subtle muffler with a deeper tone.
More than just the reduction of noise, an exhaust resonator also improves the overall performance of the engine. You will end up having a smoother driving experience since the car can produce higher horsepower and use less fuel. In a nutshell, it also improves efficiency.
Fish
Roger
Hershey, PA
2019 FORD Ranger Lariat Hot Pepper Red, 1993 F-150 XLT
HVACR
well inside the cab they can lol
Hahahahaha!!!
I guess ur right. They could make the cab sound like a 5hp peddle bicycle if they wanted 2.
Hahahaha!!!
Doc
Doc
Live oak fla
Can you elaborate on this?[/
Soundaktor
From Wikipedia, the free encyclopedia
Jump to navigationJump to search
Soundaktor (German for "sound actuator") is a vehicle audio system used to simulate engine noise in the cabin of some Volkswagenautomobiles. It consists of a speaker mounted on the firewall between the engine and the cabin, which adds noise to the cabin in order to replicate the driving experience of older vehicles that had lower levels of sound insulation.[1][2][3][4] This system was introduced in 2011 on VW's Golf/GTI,[1] and has also been used on the Jetta/GLI, and Beetle Turbo.[2] The same technology has also been used in other cars from Volkswagen Group, including the Audi S3 and Škoda Octavia vRS.[3]
The sound generated by this device has been described as "a sort of buzzy, fizzy noise".[3] It has been reported to play a digital recording of engine noise,[2][4] but Volkswagen claims that these reports are false, and that it reproduces the actual engine noise of the car.[5] Some diesel cars produced by the Volkswagen Group also have an "exhaust soundaktor". This system uses additional speakers in the exhaust system of the car to generate "a low-pitched, roaring sound" intended to make the car sound less like a diesel and more like a conventional gasoline engine.[3]
Other vehicle manufacturers have also used artificial engine noise systems, implemented in other ways. Some models of the BMW M5 add noise to the car's audio system, for instance,[1] and the 2015 Ford Mustang also added a system for sending the car's engine noise through its speakers.[4] Multiple manufacturers have shaped the engine compartment or installed resonant pipes within it in order to direct greater amounts of actual engine noise to the cabin,[2][3] a system also used by VW before switching to Soundaktor.[2]
References[edit]
  1. ^ Jump up to: a b c Webster, Larry (August 2, 2012), "The Rise of the Fake Engine Roar: To make engines sound better, some automakers are broadcasting motor noise through speaker in the cabin. Is this progress—or an affront to the purity of the engine note?", Popular Mechanics.
  2. ^ Jump up to: a b c d e Colwell, K. C. (April 2012), "Faking It: Engine-Sound Enhancement Explained; How car manufacturers are giving quiet vehicles raucous engine notes", Car and Driver.
  3. ^ Jump up to: a b c d e Robinson, Matt (2014), "5 Ways That Manufacturers Enhance The Sound Of Their Cars", Car Throttle.
  4. ^ Jump up to: a b c Harwell, Drew (January 21, 2015), "America's best-selling cars and trucks are built on lies: The rise of fake engine noise", Washington Post.
  5. ^ Hanson, Hilary (January 24, 2015), "Your Car's Engine Roar Might Be Totally Fake", Huffington Post.
Categories:
Navigation menu
  • Not
here’s one way to do it...there are all different kinds !
Regards
MTB-BRUH
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
I know what that is. A resonator is part of the exhaust
lohchief
George
SW Oregon
2019 Ford Ranger Lariat FX4 CC.
Disabled/retired
That still doesn't explain WHY one shouldn't remove the resonator. Or outright replacing the exhaust system,as so many have done.
HenryMac
Mech. Engineer - Retired
NAPA know how....
http://knowhow.napaonline.com/exhaust-resonator-explained/
The Short Answer:
Resonators are often times confused for mufflers and while they may appear similar and share some of the same jobs, they play an integral part in producing optimal volume and tone from your engine. They also have an important role in the exhaust evacuating process, which helps your engine produce more power and reduce fuel consumption at the same time.
The Long Answer
When it comes to exhaust systems, many people know the basics. Things like the header, catalytic converter and muffler are all terms that you hear often but one that often goes unrecognized is the exhaust resonator.
While you might mistake it for a muffler, the resonator actually has a very different and important job to do when it comes to your vehicle’s exhaust. Here’s a quick look at what it does.
Gas Pass
As your engine’s exhaust gases leave the combustion chamber, sound waves bounce off of the walls of the pipes and ricochet all around creating both high and low frequency noise. As engineers analyzed and improved exhaust systems, they realized there were advantages to be gained in organizing and controlling these pulses and came up with the concept for the resonator. Essentially it acts like a large echo chamber that takes the exhaust pulses and optimizes their frequencies to achieve better fuel efficiency and power production.
Set the Tone
It may look like a muffler, but the resonator’s primary function is to take the sound waves created by the exhaust pulses and fine-tune them into a more organized pattern. While this helps improve power and efficiency, it also gives your vehicle its distinctive engine sound. Whether you have a Dodge pickup or a Ferrari, many cars have their own signature sounds and it all comes from exhaust resonators.
Go With the Flow
Part of the combustion cycle involves the pistons pushing spent exhaust gas out of the chamber before filling back up with fresh air/fuel mixture, but because the elapsed amount of time this takes is short, exhaust gasses would move very slowly if not for other forces pulling the gas through. Today’s modern combustion engines also use sound waves to help evacuate the combustion chamber and move the exhaust down through the pipes and out of the muffler, and this action relies heavily on the resonator. By tuning the pulses of exhaust gas to work together, it creates stronger waves of exhaust that vacuum the gas out more quickly.
Volume Control
Aside from producing the tone of your vehicle’s engine and helping move exhaust gas along its way, the resonator also plays part in controlling the volume of sound that your engine emits. By manipulating the frequency of exhaust sound waves, it can either give your car a more throaty and loud tone or silence it for smooth peaceful driving.
Doc
Doc
Live oak fla
Don’t know, I did a muffler delete...
Regards
MTB-BRUH
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
NAPA know how....
The Short Answer:
The Long Answer
Gas Pass
Set the Tone
Go With the Flow
Volume Control
Good info, but I don’t buy it lol these things aren’t two strokes... Definitely didn’t notice any performance or fuel economy difference.
Indy650
john
Eastern USA
Resonators change the exhaust flow and sonic waves making the engine more efficient and can add some power. They can also get rid of or significantly quiet that drone sound exhausts can have especially at higher speeds. From my experience the resonators before the muffler have a bigger effect but they all have positive effects if they were added by an exhaust tuning engineer. Also sometimes they can be made from a flexible material which helps with preventing the exhaust from cracking and can help with sound (drone) traveling though the chassis.
seanellaz
Sean
Tucson, AZ
Healthcare
It’s here, the video you have all been waiting for!
I literally can’t tell any difference. Oh well only $75 and it looks better
Replaced my exhaust system cat back with a Flowmaster 717909 FlowFX Cat-Back Exhaust System made of 3.00-inch Mandrel-bent system made of 409 Stainless Steel Tubing. Deleted muffler and resonator. Had a local shop make delete pipes / inserts of 3.00-inch 409 Stainless Steel Tubing. Then wrapped the whole thing, stem to stern with VViViD 4 Inch x 50ft Black FiberGlass Exhaust Wrap, then
I painted the system stem to stern w/ 1 light coat, let it dry overnight. Then drove 5 min to local grocery shopped while it cooled then drove home, let it cool again. Some paint smell, a little smoky fumes. No fires. I then repainted in the spots that looked thin and let it dry again over night. Repeated warm cool process. Let it cool again over night. Next day headed north out of Tucson for Tortilla flats Campground (east of Phoenix). On the way out of town the system was fuming @ 1st stoplight, again no fires. By the time I got to Phx the system was baked on. No more fumes. I would advise SUPER CAUTION when curing the paint. It is solvent based and could explode killing you and all people in a 50' radius if you get it too hot wet and there is a spark. CURE. IT. SLOWLY. IN STAGES. BE CAREFUL / PATIENT NOT STUPID / DEAD.
The truck sounds like a muffled diesel @ Idle. It makes very nice noise under acceleration. Some might find it too loud but I like it. On hiway, cruising @ 75mph, it is a nice warm soft rumble. Stomp the accelerator, the turbine winds up and the truck takes off very nicely with a pronounced growl.
Some claim "Oh my gawd, wrapping a system like this will cause the system to overheat and rust or melt." So far after 3k miles this has not happened. ZERO DRIVABILITY PROBLEMS, NO ERROR CODES, SYSTEM WORKS PERFECT W/ THE COMPUTER IN THE TRUCK. ALL, SENSORS IN SYSTEM ARE BEFORE THE CAT BACK SYSTEM. I always use premium gas.
