Replaced Fan Clutch Wire Support Tube - Details / How To
NotBudule2
21 Ranger
Still curious as to what the dealerships do or would do if they saw this on routine maintenance, does the mechanic really want to replace the whole damn clutch or does he just replace the hose ?
Stevedbvik1
2022 Ranger Tremor XLT
Basics the swap would need.
Using the 24 Ranger 2.3 (Wiring Diagram) for Cooling Fan Control
1. A dual fan assembly and a way to mount the assembly
2. (2ea) relays added and wired in to power the fans with 80-Amp fused power, so the addition of a fuse block and a relay center.
3. A separate fuse for (Relay Coil) Power 20-Amp
4. Reprogram the PCM to change it from pulsing ground to the clutch (fan) to the dual fan set-up.
The fans would have to have a controller incorporated into them.
5. The (Various Inputs) - Engine Temp, AC Clutch etc would already be in the PCM
Reprograming the PCM would be the biggest hurdle with this.
As both fans would always be HOT and running, but the PCM & Fan Controller would be controlling the speed they are turning
Being that Ford does not produce the hose separately they MUST replace the assembly as that is the only way for them to get it and plus there is NO PROCEDURE in the manuals for them to only replace the support tube/hose.
Unless there is a Service Message (procedure) written by Ford to allow a short cut replacement of only the tube/hose this will always be the case - Replace the Assembly but they will have to provide and list a part number for the hose or list it as locally (raw) stock and a precise length if that short cut repair were to be approved.
To be honest - I think that if it came down to it - Ford COULD void the warranty on the Fan Clutch by replacing the tube/hose and taking it out of OEM configuration - for those that use the alternate replacement.
Although it being a better supportive solution over OEM, we already know Ford & Warranty issues being covered are a coin toss.
NotBudule2
21 Ranger
If I were able, and out of warranty, I would like a "break away" harness or connecter on mine somehow, the thought of those wires getting yanked out like that is the stuff nite mares are made of, the ones you can see are bad enough, but what got pulled on and where ? I don't like it ?!!!
98RangerDave
Inland Empire CA
2020 Ranger XLT FX2 / 1997 Ford Ranger XLT
Finance
Just spotted the issue on my 2020. I’ve only have the truck for a little over a week but still, during a peek under the hood it was spotted, busted the write up on this thread to make the fix.
What a ridiculous design Ford used for this, garbage actually.
TJC
Ford has several key areas that have other "ridiculous garbage designs." The 5G Ranger had such promise, but Ford chose to cut corners in key areas.
98RangerDave
Inland Empire CA
Finance
good to know. Since I did buy my truck used. Are there any other areas I should be looking at to check for wear or age? The truck has 51k miles and was owned in Arizona, so not much rust or road salt issues. I’ve been a Ford owner all my life and not afraid to get my hand dirty with maintenance.
TJC
Issues so far. Some very common, others not so much, but still need to watch for.
  • HVAC Plenum doors warping - clicking under dash (replacement requires entire dassh removal)
  • Driveshaft vibrations / center shaft bearing failures ) seen at <25 mph (shudder) >75mph (violent shake)
  • Water dripping into #4 spark plug well (Cowling leaks at the seam - spark plugs corrodes /welds to aluminimun head)
  • Early battery failures (BMS settings prioitize fuel economy over battery life)
  • Bed leans to one side
  • Fuel in oil (nature of the beast)
  • Rear brake pad fail (uneven wear on pads - possibly sticking)
  • Exploding tranny (CDF drum, Throttle body, Shift Solenods)
  • EGR DPFE sensor fails prematurely (bucking under light load)
I think that this covers the bases.
TJC
Forgot that one! I have heard a clunking recently coming from the back suspension when I hit a bump. Changing oil this week and will inspect to see what is loose/broken.
It may be just the angle of the pic (as taken) but it appears the hose is rather short (In the first pic) The hose should be longer than the (OE) that had the molded shape.
So, a longer hose will pull it (UP) away from the pully.
That module will flex some and as viewed (as you are standing) in front of the truck - rotates C/W, so if the pic (is accurate) the hose could easily pull down on the pully.
Just wanted to point this out
Example:
TJC
I'd change the clamps around as well. There is a pull on the engine end of the hose that does not exist on the clutch sensor end. In fact. I'd ditch the spring clamp. (it was previously on the clutch end of the hose from the factory)
98RangerDave
Inland Empire CA
Finance
thanks! I bought a 10 pack of hose clamps, so I’ll swap another one where the spring clamp is. Appreciate the help.
98RangerDave
Inland Empire CA
Finance
Example:
Thank you. I ended up making my hose about an inch longer than the OEM broken one I removed. I did but about 2 feet of hose though, should I cut a longer piece and refit it? I had my wife start the truck while I watched this replacement setup and it doesn’t move much. Don’t know if that’s a good thing though.
TJC
The sensor was originally clocked at 10 or 11. Yours looks to be at 12.
