Rear lift block install
TruckNorris
Brad
NC
21XLT FX4
Technician
Im sure this has been covered, but i cant find much info. How do you install rear lift blocks? I have some 1 inch blocks i want to install. Thank you
I placed jacks under rear frame, removed the U-bolts and jacked up the axle on one side off the springs, put the block in position with new longer U-bolts, reverse installation and move to the other side...
TruckNorris
TruckNorris
Brad
NC
21XLT FX4
Technician
Does the block go on top of the shim?
TruckNorris
TruckNorris
Brad
NC
21XLT FX4
Technician
Also the blocks are tapered. Which way are they suppsed to go?
Did they include instructions? I think the blocks go on bottom of spring if you want to lift...not sure it can do the reverse...I recall there were register holes on the block to keep them in place...don't remember about any tapering...are you using Eibach blocks? Those are what I used...
Glocker
Boca Raton
I would run from that block.
The Ranger leaf springs are weaker than hell and have been known to bend on their own and even break. They have also been known to bend around backward over lift blocks. I'd go with the BDS lift shackles before I installed the block.
SDXLT
Josh
San Diego
2021 XLT FX4
I have a set of BDS shackles to sell if you’re interested PM me. They’re brand new.
Todd Chapin
Todd
Alexandria
2019 crewcab lariat fx4
Chef
I have had my Eibach 1" blocks for 25k miles not one issue. They do what they are suppose too. I did not install them but my mechanic said it was very simple thing. Give me a bit of rake. That said my next suspension upgrade would be multi pack rear leaf springs.
OFC Ranger
Jack
ZR2
I run a 1" eibach block in combination with autospring leaf helpers. So that probably resolves any possible breakages regarding factory overload leaf.
The blocks simply go under the leafs. Undo rear shock bolt, undo 4 leaf u bolts. drop axel a bit, put block in, reassemble. 1 hour job for both if that.
TruckNorris
TruckNorris
Brad
NC
21XLT FX4
Technician
Sent you a pm
I know this isn't Raptor tech nor do I car to race this truck...for everyday use and light off roading, it works for me...
