Yesterday, I had to get in my Lincoln to get something and I didn't have the key in my pocket. Rather than go inside and get the key, I used the code.So what are the advantages? If you walk up to your Ranger with key in pocket it will automatically open wen you touch the inside of the handle. Lock by touching the lock sensor area on the front.
The keyless entry works identical to those without it, but it lets me run out to the truck in the driveway without grabbing the keys and I also lock everything inside while I'm working out. It's a small feature but once you get used to it it's hard to live without it.So what are the advantages? If you walk up to your Ranger with key in pocket it will automatically open wen you touch the inside of the handle. Lock by touching the lock sensor area on the front.
Well, I'd like to know this as well! Tha would give me a reason to pursue the Accessory version if it doesn't look too tacky!I went out and put the key fob in the truck and then locked the truck with the keypad. Then I tried to open the door by putting fingers under the door handle against the sensor and it stayed locked! So you are right VAMike if that's what you were saying. Now has anybody heard that the key fob locked in the truck could do anything to the car battery? Where I read that, they were talking about some other Ford vehicle and not the Ranger.
This has made my day if I can leave the fob in the truck and just use the keypad to get in!
I've locked my FOB in my Fusion a few times and NO issues. If you use the keypad to lock the car with the FOB inside (and that is the only way I know how to do that), you have to use the keypad to gain access. The doors do not unlock by touching the inside of the door handle. One obvious warning tho....do not lock the FOB in the car in plain sight - hide it.I have the same question as chasvs. Beginning to wonder if it was worth the trouble and wait to get the keypad. My main reason for getting it was so that I could lock the key (in this case fob since I have a push button start Lariat) in the truck and not have to carry it around. I guess the fob could be locked in but with the door handle sensor, all someone would have to do is reach under the handle and the truck will unlock. Plus I read somwhere on line that if a fob is locked in the vehicle, it could eventually drain the car battery. A person could go unlock the truck with the keypad if the fob is not close by but then still can't start the truck until the fob is close by. Being a bit repetitive here but just wondering if I've got this figured out. Or am I missing something?
