Programming Garage door opener
dtech
colorado
In my old house I had the original garage door opener ~ 30 yrs old and it wouldn't work with the newer home link transmitters in newer autos.
Deleted member 15875
What kind of door opener and how old?
Also, were you able to get the button(s) in the truck programmed and can’t get it to be accepted by the opener, or can you not get the truck opener to accept the signal from your existing remote?
Maybe you could post of video of what’s happening….
Chamberlin....They aren't new, but work fine. I cannot get the Ranger to program.
alcohenusa
Alan
CO
2020 Ranger Lariat 4x4
I would try starting over and erasing the buttons. When I followed the manual’s directions exactly, I had no issues. In my old house the door opener was from 2003 and worked fine.
Here’s the process to erase all the buttons:
Erasing the Function Button Codes Note: You cannot erase individual buttons.
1. Press and hold the outer two function buttons simultaneously for approximately 10 seconds until the indicator light above the buttons flashes rapidly.
2. When the indicator light flashes, release the buttons. You erased the codes for all buttons.
Yep, I've tried every method imaginable. Seems so simply, right? But I've still had no luck
alcohenusa
Alan
CO
Are you using using an original Chamberlain remote to program the truck?
Yep, and I've also tried using the main unit button in the garage and going back and forth. It looks so simple on YT vids. I've reset, you name it.
alcohenusa
Alan
CO
I guess it’s possible you have a bad homelink module. May be time for the dreaded dealer visit.
alcohenusa
Alan
CO
Honest question; what can the dealer do?
I would expect that they have to have a way to test the device to see if it works and replace under warranty If it’s bad.
Another stupid question, but have to ask…. Do you have the vehicle on (but not running) like the directions say? Also, the only other thing I can suggest is to disconnect the battery and let everything reset if you haven’t tried that.
I've tried vehicle on, not running, running, and completely off. :crying:
The lights flash on the visor so I don't think it's a Ford issue to be honest.
dtech
colorado
Have you contacted Chamberlain support ? I did when mine wouldn't work - and they confirmed I was sol because the newer openers aren't backwards compatible with the older RF , but they may have had a similar case as yours with Ford vehicles.
I just ordered another remote door opener from their site. Hopefully it's easy to program now. I'm sure they will tell me the same then. Thx
bmxandfmx
Richard
Litchfield Park AZ
2022 Ranger, 2021 RSQ8, 2021 RS7, 2014 Camry
USAF
I know this is an older thread but wanted to add this bit of info to it. I’ve spent the last few days chasing my tail to find out that homelink apparently will only program of a name brand remote, I.E. lift master, genie, etc. if you have the generic ones from Amazon or any universal remotes it won’t work for the first steps of the programming process.
Good luck everyone!
Man, I lucked out. We have an old Stanley that was manufactured before 1992 and it connected right up with my wife's 2022 Mazda CX-5. Talk about lucky!
Isn't there some sort of module to do a retrofit? Like this HomeLink Compatibility Bridge for LiftMaster and Chamberlain (post-2011) garage doors?
https://www.chamberlain.com/homelink-compatibility-bridge/p/HOMELINK+RPTRMC
step aside Cybertruck, look at this tech! It's even got an antenna the size of a Ranger's!
gee, it's even the lowly economy model =p
