Problem with 4th gear?!
RangerKody
Kody
Orlando, FL
Hey y’all,
Does anyone have a problem coming off a cold start and going into 4th gear for the first time. When my truck does it goes into 4th and feels very harsh going into it and then immediately goes to 5th, acting like it should have skipped 4th. It only does it the first time on a cold start.
I’ve had the update from the rough idle but this has been happening before that. Guess I’ll call tomorrow.
MTB-BRUH
Tyler
Shingletown CA
2019 Ranger Base
Shop Manager
Pretty sure my truck skips 4th when driving normal. I would get that checked out
RangerKody
RangerKody
Kody
Orlando, FL
Yea mine skips it to after the first cycle of the gears which is weird. Only does it the first time it cycles from 3rd to 4th to 5th from a cold start. After that it skips 4th entirely.
RangerKody
RangerKody
Kody
Orlando, FL
Weird as in why it doesn’t skip the first time either. I know it’s normal for this transmission to skip gears.
RangerKody
RangerKody
Kody
Orlando, FL
Dropped off today so they will have it for a couple days to properly diagnose it. The guy who checked me in was like maybe that’s a characteristic of the transmission but I haven’t seen anyone with the same problem on here. Told him if that’s the case it isn’t leaving the dealership.
jwtayl01
Jesse
Syracuse, NY
2019 Lariat
I have this same problem. Seems to be cold start only. Not sure if it 3rd to 4th to 5th. But definitely 4th to 5th.
RangerKody
RangerKody
Kody
Orlando, FL
Yea it’s definitely not normal. I’ll keep you posted and see what they say but might be best to take it in.
dcgibs
Florida
Ford Ranger 2019 - 4x2 SuperCrew
Yea I would be curious. Mine has a jerky 3rd to 4th in the morning, and 4th to 5th ain't so hot either.
RangerKody
RangerKody
Kody
Orlando, FL
Today’s update. They called and they were able to feel what I was talking about. They have to clear the “keeper live” memory? Something in the computer is communicating to the transmission to hit 4th gear when it shouldn’t? They need another day with it. Here’s to hoping!!
RangerKody
RangerKody
Kody
Orlando, FL
Got it back tonight but I’m pretty sure I felt it again. Going to see how it feels in morning on a cold start again.
Mokume
Honolulu, Hawaii
Ah yes, the marvels of electronically controlled transmissions!
Just reflecting here, does anyone remember the old vacuum transmission modulators in years gone by?
The diaphragm in it would rupture, sucking ATF into the engine creating clouds of white-gray smoke out the tailpipe.
And when the transmission did upshift (governor pressure prevailing) you swore that the driveshaft was going to twist itself into a pretzel.
However, you did not worry about the 9" rear end, that thing could take hundreds of shock loads at not even notice.
Ford even installed a smaller version of it in certain Pinto's, now that's engineering overkill.
RangerKody
RangerKody
Kody
Orlando, FL
Felt it this morning on a cold start :( guess ford customer care it is. This was the 3rd attempt to address the problem.
DannyL
Danny
Torrance CA
2013 Mustang GT CA Special. Ordering a Ranger Lariat FX2 Supercab in February 2020
Yeah I can attest to the Pinto rear end. I put a 450hp 302 and C4 tranny in a pinto wagon using the stock rear end and never had an issue.
Smoked a number of Camaros, Mustangs and Vetts with that car
ch47dmechanic
SF Bay Area
Keeping an eye on this as the TSB fixed this issue in my truck. Also, pre TSB upgrade, even if the engine was cold and I accelerated harder than normal, it wouldn't have the "4th gear issue".
f_399
AJ
Manila
Ranger Raptor - Ranger Wildtrack - Ranger XLT - Everest
have the same thing with the raptor here in the philippines
when its cold, 3-4(or 5) is either rough or there is a long delay
gets better when warmed up
