SandBaja
I applaud your curiosity and persistence. I have been in the technology field for almost 40 years after being trained in electronics and ASW in the Navy. I have always been engaged in electronics with knowledge in radar, sonar and camera systems and heavily engaged in electronics and electromechanical interfaces to hardware, firmware and software. That said, I don't know specifically how this works but have a great deal of practical experience.Just out of curiosity do you have adaptive cruise.
There are typically tools and diagnostics available to the manufacturer to verify operation. These tools and diagnostics are generally not available to the average person. My guess is a device able to hook into the bus and observe the camera and it's recognition sensitivity. I would suspect something similar with the radar.
One can go on faith that the system works as advertised or one can delve into it as you have done. Sometimes a simple test (such as a plastic bag you used) will work and sometimes the system is better at recognizing a true event. The camera system is likely using image and shape recognition and there are typically levels of sensitivity that can be set. Radar uses different methodology and if present on yours likely works in conjunction with the camera system. The SW coding is very complex and must be exceptionally fast, if in a vehicle, IMO.
I think I recall you saying you took it in and the dealer verified operation as expected. If I were hell bent on an answer I would have asked to speak to the mechanic that verified it's operation and confirm his testing was more than cursory.
This link is to an early 2014 article talking a bit about testing and image reco software and talks a bit about shapes, etc.
https://www.cars.com/articles/2014/...strian-detection-to-collision-warning-system/
Adding a second link from 2015.YouTube video showing operation.
Good luck!
