SandBaja
Are you certain about that? I don't see a sensor located near the drivers side lower grill but it is fairly well buttoned up. I think 2.7 ecoboost is correct. It is misleading and talks about both the camera and radar, in the manual, but the warning about the snow plow indicates lower grill, not camera.
That said, it also appears that the radar which we do not see seems to work in conjunction with the camera.
Adjusting Pre-Collision Assist Settings You can adjust alert and distance alert sensitivity to one of three possible settings by using the information display control. See General Information (page 88). You can switch the distance alert and indication function off using the information display controls. See General Information (page 88). If required, you can switch active braking off using the information display controls. See General Information (page 88). Note:We recommend that you turn the Pre-Collision Assist system off if you install a snow plow or similar object in such a way that it may block the radar sensor. Your vehicle remembers the last selected setting when you switch it off and then back on.
Blocked Sensors
E271779 If a message regarding a blocked sensor or camera appears in the information display, the radar signals or camera images are obstructed. The radar sensor is located behind a fascia cover near the driver side of the lower grille. With an obstructed radar, the Pre-Collision Assist system does not function and cannot detect a vehicle ahead. With the front camera obstructed,
the Pre-Collision Assist system does not respond to pedestrians or stationary vehicles and the system performance on
moving vehicles reduces. The following table lists possible causes and actions for when this message displays.
ActionCause Clean the grille surface in front of the radar or remove the object causing the obstruction The surface of the radar in the grille is dirty or obstructed in some way. Wait a short time. It may take several minutes for the radar to detect that there is no obstruction. The surface of the radar in the grille is clean but the message remains in the display. The Pre-Collision Assist system is temporarily disabled. Pre-Collision Assist should automatically reactivate a short time after the weather conditions improve. Heavy rain, spray, snow, or fog is interfering with the radar signals. The Pre-Collision Assist system is temporarily disabled. Pre-Collision Assist should automatically reactivate a short time after the weather conditions improve. Swirling water, or snow or ice on the surface of the road may interfere with the radar signals. Contact an authorized dealer to have the radar checked for proper coverage and operation. Radar is out of alignment due to a front end impact. Clean the outside of the windshield in front of the camera. The windshield in front of the camera is dirty or obstructed in some way. Wait a short time. It may take several minutes for the camera to detect that there is no obstruction. The windshield in front of the camera is clean but the message remains in the display. Note
roper system operation requires a clear view of the road by the camera. Have any windshield damage in the area of the camera's field of view repaired. Note:If something hits the front end of your vehicle or damage occurs, the radar sensing zone may change. This could cause missed or false vehicle detections. Contact an authorized dealer to have the radar checked for proper coverage and operation. Note:If your vehicle detects excessive heat at the camera or a potential misalignment condition, a message may display in the information display indicating temporary sensor unavailability. When operational conditions are correct, the message deactivates. For example, when the ambient temperature around the sensor decreases or the sensor automatically recalibrates successfully.
Blocked Sensors
. I don't have a front license plate so that's not my issue. Can someone check and see if/where the radar is and post a pic?
