P228D fault code
boston
uk
2017 Ranger
I had the P228D fault code today. Below is a readout. Do you think this is a simple PCM update needed due to trash Ford programming or does it look like a machanical issue?
2018 Ford Ranger 3.2
Codes:
PCM: P228D:00-68
BdyCM: B1A79:15-48
BdyCM: B115E:08-0A
(OBD2, TCM, APIM, PAM: none)
Code: P228D - Fuel Pressure Regulator 'A' Exceeded Control Limits - Pressure Too High
Status (-68):
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
- Test not complete
Module: Powertrain Control Module
FORScan DTC details:
This DTC is set during the pressure decay function where the injector response is tested in terms of reducing fuel rail pressure. Occasionally a too high pressure decay is produced.
Currently this behavior cannot be anticipated by the software and the DTC can be raised.
This is a lack of robustness of the software programming issue not an injector or high pressure pump issue.
If this DTC is set it will stop the injector from supporting fuel rail pressure decay requirements.
Individually this will have no effect on vehicle performance.
If all cylinders have raised the injector leaking DTC, fuel rail pressure may be high during deceleration events.
Delete the injector leaking DTC if present.
If P228D is present and all cylinders have raised the injector leaking DTC then delete P228D.
Update the PCM with the latest calibration.
Freeze Frame #1:
EVENT_TIME: Wed Nov 25 09:38:11 2026
TOTAL_DISTANCE: 150529 km
RUNTM: 237 s (time since engine start)
LOAD: 11.37 %
ECT: 39 °C (coolant)
MAP: 105.0 kPa
RPM: 754
VSS: 29.0 km/h
IAT: 6 °C
MAF: 21.41 g/s
EGR_PCT: 0.00 %
EGR_ERR: 0.00 %
BARO: 101.0 kPa
AAT: 5 °C
APP_REL: 0.00 % (accelerator pedal)
FRP_ABS: 91250.0 kPa (fuel rail pressure)
FRP_DSD / FRPD: 25000.0 kPa (desired)
FRP_A: 91096.0 kPa
FLI: 18.04 % (fuel level)
FRT: 8 °C (fuel rail temp)
FTA: 8 °C
ECU_INTERNAL_TEMPERATURE: 17 °C
MIL: Off
Monitors: catalyst, EGR, evap, fuel system, misfire, O2 sensor, O2 heater all evaluated
aspenridge31
Chattanooga
2011 Ford Ranger XLT
Your freeze frame fits that FORScan description, cold engine, pedal at zero, 912 bar against 250 desired while decelerating. No injector leaking codes in your scan, so it points to the software issue, not the pump. I'd clear it and get the latest PCM calibration, then watch for a return.
For me - I would clear the code and monitor (Live Data) FRP at idle and above idle.
Does FRP actual follow desired? fairly closely
with this Freeze Frame - being (off throttle) generated it may just be a nuisance code.
yes it could be software related (false coding) the transition but if it just started doing it - i would monitor what actual FRP vs Desired PIDs are reading.
The software calibration is about when the code generates - not the pressure readings
boston
boston
uk
2017 Ranger
Thank you
boston
boston
uk
2017 Ranger
In the past we did have the truck cut out a couple of times when we had just come off throttle to a complete stop. Thisnhad happened after a complete stop as well. But thisntinebwent into limp mode.. I will monitor FRP today and post results
boston
boston
uk
2017 Ranger
Can I only get the lastest from Ford?
