Duptj
- First Name
- Tim
- Joined
- Jan 9, 2020
- Threads
- 1
- Messages
- 4
- Reaction score
- 0
- Location
- Nashua New Hampshire
- Vehicle(s)
- 2019 Ranger Lariat/FX4 with appearance package, 2019 Edge Titanium
- Thread starter
- #1
Just before the new year when starting the truck I received the following messages in the left hand display....
Terrain management fault, fault in advance trac, fault in abs system, park aid malfunction, hill start assist warning,
pre-collision not available and there may be others I missed.
After clearing those out I was left with the ABS and TCS light on in the dash.
Restarting the truck several times seemed to clear the issue on that day but in the following days it was hit or miss on when it would happen.
When this happens I am unable to switch from 2WD to 4WD or vice versa. Also the auto stop start didn't function.
Other than that the truck appeared to run fine and drive fine.
Dropped the truck at dealers on 1/6 and received call yesterday that it was fixed. When I picked it up it was doing the same thing....
if it helps the notes on work order state the following...
"retrieve dtc c0034-25 ppt b1=n, b2=y, b3 inspect abs module harness and connector for pin issue access module, inspect right front sensor harness and connector c160 resize pins reinstall all connectors and road test no light returned"
Guess they forgot that it happens when starting and a road test wouldn't tell them anything.
Service advisor seemed surprised that there still was an issue. After he went back to speak with the technician my truck went from being fixed to the part needed for repair was going to be in sometime next week and to just drive it like it was.
You see, when I dropped of the truck they had no rental for me so they called Enterprise. I was given a 2019 Expedition Limited to drive. When I refused to take the truck not repaired, the wouldn't let me take the Expedition back and instead put my in one of their vehicles, a 2018 Eco Sport piece of junk. So I guess the lie that my truck was fixed was simply to get me out of the Enterprise rental.
Anyways, the part that I was told I needed is some sort of ABS sensor. They said this would fix all my problems.
I have no confidence in that statement.... anyone have similar problems.
Sorry for the long first post and thanks for the add.
