boston
- Thread starter
- #1
I had the P228D fault code today. Below is a readout. Do you think this is a simple PCM update needed due to trash Ford programming or does it look like a machanical issue?
2018 Ford Ranger 3.2
Codes:
PCM: P228D:00-68
BdyCM: B1A79:15-48
BdyCM: B115E:08-0A
(OBD2, TCM, APIM, PAM: none)
Code: P228D - Fuel Pressure Regulator 'A' Exceeded Control Limits - Pressure Too High
Status (-68):
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
- Test not complete
Module: Powertrain Control Module
FORScan DTC details:
This DTC is set during the pressure decay function where the injector response is tested in terms of reducing fuel rail pressure. Occasionally a too high pressure decay is produced.
Currently this behavior cannot be anticipated by the software and the DTC can be raised.
This is a lack of robustness of the software programming issue not an injector or high pressure pump issue.
If this DTC is set it will stop the injector from supporting fuel rail pressure decay requirements.
Individually this will have no effect on vehicle performance.
If all cylinders have raised the injector leaking DTC, fuel rail pressure may be high during deceleration events.
Delete the injector leaking DTC if present.
If P228D is present and all cylinders have raised the injector leaking DTC then delete P228D.
Update the PCM with the latest calibration.
Freeze Frame #1:
EVENT_TIME: Wed Nov 25 09:38:11 2026
TOTAL_DISTANCE: 150529 km
RUNTM: 237 s (time since engine start)
LOAD: 11.37 %
ECT: 39 °C (coolant)
MAP: 105.0 kPa
RPM: 754
VSS: 29.0 km/h
IAT: 6 °C
MAF: 21.41 g/s
EGR_PCT: 0.00 %
EGR_ERR: 0.00 %
BARO: 101.0 kPa
AAT: 5 °C
APP_REL: 0.00 % (accelerator pedal)
FRP_ABS: 91250.0 kPa (fuel rail pressure)
FRP_DSD / FRPD: 25000.0 kPa (desired)
FRP_A: 91096.0 kPa
FLI: 18.04 % (fuel level)
FRT: 8 °C (fuel rail temp)
FTA: 8 °C
ECU_INTERNAL_TEMPERATURE: 17 °C
MIL: Off
Monitors: catalyst, EGR, evap, fuel system, misfire, O2 sensor, O2 heater all evaluated
Codes:
PCM: P228D:00-68
BdyCM: B1A79:15-48
BdyCM: B115E:08-0A
Status (-68):
- Test not complete
Freeze Frame #1:
LOAD: 11.37 %
MAP: 105.0 kPa
RPM: 754
VSS: 29.0 km/h
IAT: 6 °C
MAF: 21.41 g/s
EGR_PCT: 0.00 %
EGR_ERR: 0.00 %
BARO: 101.0 kPa
AAT: 5 °C
FRP_A: 91096.0 kPa
FTA: 8 °C
MIL: Off
