TJC
- First Name
- Tony
- Joined
- Aug 28, 2020
- Threads
- 47
- Messages
- 4,100
- Reaction score
- 10,427
- Location
- North Carolina
- Vehicle(s)
- 93 Miata, 05 Ranger 4x4, 20 Ranger 4x4, 23 CX-5
Time and wear I think. We had been monitoring it for a month or two after the initial work was completed. And knew we had to figure it out. You can ignore the signs, but you will invariably end up on the side of a road if you let it go too long.Glad you caught it before major problems. Sounds like you were pretty on top of the maintenance on that rig. Which kind of leads credence to my point.
Wonder what happened with that one? Impact damage anywhere? This was the factory driveshaft?
Good point about the slip joint lube. And a good reminder to me. Thank you.
It was a massive overhaul effort as my wife loves the 2005 Ranger. We replaced a lot of front suspension parts, AC compressor, shocks, brakes (including rotors), all fluids, front wheel bearings, as well as engine and transmission. Only axles and transfer case are original now. We paid 19.5K for it new in 2005. We invested $12K in parts and labor to bring it back to new form. I think it is good for another 200K miles. It has 10K on it since the refresh. It has been garaged its entire life and looks great. The 2020 Range sits right next to it in the garage.
It was the factory driveshaft, and it had 150K on it. I think the yoke and u-joints simply wore out and it was time to replace them. There was dark scuff marks along one side of the shaft and they were not there before the work began, but the shaft appears to be straight. No obvious dings or dents, simply rather loose, but not sloppy loose u-joints. I would have not thought them bad.
I had the bed liner sprayed by Ford when new, and it has lifetime warranty. 17 years later it is going back to Ford to be redone - hopefully for no cost!
