Obscure/little things you love on the Ranger
Phil, I sure hope Ford has a better retirement plan than that! Ha Ha.
Hi Chuck,
Well...the next level up got two pencils. Gold watch was up one more level from the two pencils! :blush:
Ford Motor Co Retired
SubVet
Myrtle Beach
The Unleashed Tune !
Regards
I am a tad hesitant about tuning. I have run tuners on my bikes, Probably the same as a truck to install.
Tacoma has 60,000 posts in a OV Tune thread a ton of Tacoma buyers are having to buy IF they want any performance at all. That $800 is a must for Taco owners, I almost flashed my 2016 but I decided not to put lipstick on a pig and moved on the Ranger.
https://www.tacomaworld.com/threads...lopment-thread.495735/page-2663#post-21791945
Doc
Doc
Live oak fla
Yes, you always take a chance at warranty, but here are my results..
Hot Pepper Red Zeppelin
Earth
2019 Ranger XLT
Discovered this a while back....
Bump the turn signal stalk and the turn signal flashes 3 times.
Deleted member 1634
Perfect for changing lanes. Ford has had that feature on a lot of vehicles for quite a few years now. Personally I'd prefer it to flash at least one more time. Seems like it usually uses up the 3 flashes before I'm even halfway merged into the lane, at least at my "slow" merging pace.
SRAces
Lake Park, GA
2019 Ford Ranger, 2015 Mercedes-Benz GLA, 2004 Mercedes-Benz SLK 230 Special Edition
USAF (retired)
Some of us are "old school" and were taught that you start signalling before moving to the next lane and stop signaling when you get in the next lane. So for me that's usually at least 5 flashes of the indicator. I never use the "bump" feature. Then there are those on the road that don't know what a turn signal is or is used for. Sad, but a product of the times and the generation gaps. Used to be every 18-wheeler used their signals for everything. Now they drive just like 4-wheelers do. SMH.
joeb427
Lexus had/has an adjustment of 3,5 and 7 flashes which is nice. 5 is what I would go with.
I'm pretty sure you can change the number of flashes in FORScan.
UncleBob
Fullerton, CA
2019 Ford Ranger Lariat SuperCrew 2WD in Magnetic
I hope so. My bride's Hyundai Sonata is configurable to choose between 3,5,or 7 blinks. I chose 7. As soon as I learn how to use Forscan and get the necessary tools, I will be playing with those settings.
dmeyer302
Daniel
Carthage, MO
2016 Odyssey, 2021 F-150
Mechanical Engineer
I bought a trailer tonight. Just a 6x10 flatbed, nothing too exciting. The trailer was missing one light. The Ranger was smart enough to tell me that the left light was malfunctioning, and it did a hyperlink on the left turn signal as well. This all happened even though I have disabled hyperblink in Forscan for my LED replacements. So this is a nice feature to keep you aware of what your trailer is doing.
T-Wrecks
Roberts, WI
19 XLT FX4 S Cab, FX4, 301A, Tow, Technology
I thought there was a thread on unusual odd things we’ve found with our trucks but couldn’t find it. Here’s what I came up with during the first 1000 miles.
When you turn the steering wheel while on autostop the engine starts and stays running. So if you want to start the engine w/o taking your foot of the brakes this works. It’s odd because I thought the power steering was electric, so there’s no need to start the engine if you have to turn the wheel?
If you are in sport mode in a high gear (8+) at 1500 rpm or less and go to WOT the throttle doesn’t open at all. It just keeps going same speed as before (you can hear the throttle open when it does). If you are in a lower gear or add more RPM the throttle opens but does so slowly as it builds more RPM. This is drive by wire nanny taking over. We are not in control of the throttle, the ECU is. I did this to try and find the vibration the some have mentioned at 45-60 mph (didn’t find anything other than this).
SubVet
Myrtle Beach
I like that you can put the vehicle in reverse while moving and turn on The Back-up Camera. yes I tried it works well...don't ask
found this
I saw this a while back and as much as I want to try this, I just can't bring myself to do it. :shock:
