New tires 275/70/17
KTM0620
Keith
Roseville Ca
2021 Ford Ranger Tremor 2017 KTM 1090 Adventure R
After much research went with some 275/70/17 Falken AT4W load C. I do have 1" level, no rubbing yet, but think they will with some articulation turning. pretty happy with how they look.
RangerPNW
Thomas
Santa Fe, NM
Looks good, i went with the same size in a KO3. I had rubbing, but am running 30mm wheel spacers so you're probably gonna be fine on stock wheels.
Jmoores
Richmond, Virginia
Health Insurance Executive
Tires look great! I'm shopping for new shoes for my 2021 Tremor. Down to Falken Wildpeake at4w or Micky Thompson Baja Boss. Thoughts?
Bob902
St. Louis
RETIRED!!!!
I have had the Falken AT4W for over a year now. Still look brand new. Ride is good and virtually no noise. I would definitely buy them again.
KTM0620
KTM0620
Keith
Roseville Ca
Those were the 2 I has looking at, the Baja boss didn't come in the 275 and I really wanted to stay load C. I'm really happy with the Falken's. so far no rubbing, I do have the 1 inch level. Did a couple hundred mile out in the desert did great. they are a bit heavy but don't really notice it. Gas mileage is about the same(Fuelly App). one thing I did notice my speedo is spot on now, at 65 GPS always read a couple MPH slower. now its perfect.
Jmoores
Richmond, Virginia
Thanks for the insight. Are you running LT's or Standard Load? Seems like LT's may be too heavy for our Rangers, but I'm not sure.
Bob902
St. Louis
RETIRED!!!!
Just the standard load tires.
Josh275
Josh
Montana
Employed
I just put the Mickey Thompson Baja boss's on my 21 tremor in 275/70/17, highly recomend. I ran the grabbers, then toyo at3's, and now the baja boss and they are by far my favorite.
YaBoiNewton
Automotive Engineer
Running E load 33s and it's not bad. Fuel economy is worse in the city, about the same on the interstate.
Jmoores
Richmond, Virginia
Thanks for the recommendation, Josh. Were you able to fit 275/70/17 without modifications?
Josh275
Josh
Montana
Employed
I was able to fit them with the smallest lift available from 'fordrangerlifts'. They do rub on the front crash bars slightly on uneven terrain, but I should be able to loosen the bars and have enough play to get them out of the way.
KTM0620
KTM0620
Keith
Roseville Ca
Where did you find those tires in that size? cant find that tire in that size. probably would have went that route if they where offered. But I'm more than satisfied with the AT4W with the 1" lift I'm getting no rubbing at all.
JohnnyO
Jon
Pittsburgh, PA
2020 Ranger STX 4x4
Tire Rack has them.
The only 275/70-17 I could find that wasn't a 10 ply Load Range E.
Thanks for the info. I have a 1.5" level and 265's and was wondering if 275's would fit.
https://www.tirerack.com/tires/tire...R7WPAT4W&vehicleSearch=false&fromCompare1=yes
