awd.nv
- First Name
- Anthony
- Joined
- Apr 26, 2021
- Threads
- 30
- Messages
- 1,264
- Reaction score
- 2,394
- Location
- Las Vegas, NV
- Vehicle(s)
- '21 Ranger XLT Tremor
- Occupation
- Computers
Man dude, yeah and this is why I don't have time to work on my own cars anymore. I been there when a job takes longer than it should. The worst ones are like the experience you went through, should be easy then turns into a mess.In every video that someone is putting the level kit on, it's an aluminum knuckle but I figured the Tremor was gonna be different. I got the 2" level, it sits a little squatted when you get the measuring tape out but from a normal perspective its plumb dead level.
On top of it being a nightmare to do, I couldn't get the control arm out of its spot and essentially needed Thors bloody hammer to get it out. I somehow in the process of using the hammer, managed to get the bolt to unscrew a little bit, and stripped the damn threads on the passenger side.... On a Friday.... At 6:30PM.......
Luckily I was able to chase the threads and get it to work but holyyyy chit... that was a bear.
I eventually got it out with another set of hands helping hold the pitman puller along with modifying it slightly so the point wouldn't walk on the soft metal of the control arm ball joint.
It does seem like the 2" level makes it visually level but wheel well technically lower, I think it is the angle of the hood that makes things look level and right. I think I would try a 1.5" spacer if anyone made one or if I change to coil overs I could get that stance, I just hate the bed squatting when I have a load so the 1" does the trick for me right now.
