Lumpy idle no power
lball1999
Liam
Hereford
ranger wildtrak 2.0
So I've got a ford ranger 2.0 biturbo that idles like a bag of nails has hardly any power I've done a compression test and changed the injectors but this hasn't done anything any ideas
  • Wow
RangerBill
PA
We don't have the diesel in North American Rangers. Have you checked for any DTC codes?
JasonTremor
2021 Ranger Tremor XLT
Trouble codes could lead you to the source of the issue. Visually check all the turbo charge pipes and look for compromised hoses and wiring harnesses. Use a good live data code scanner to check for lift pump fuel pressure coming from fuel tank supplying high pressure fuel pump and check high pressure fuel pump output readings post injection pump. Should be able to see all these readings on a good live data scanner.
My12SecRanger
Patrick
Las Vegas
21 XLT Ranger 2wd
Ford Tech
my first thought was vacuum leak or timing issue?
bill_AUS
Billy
Victoria, Australia
2020.75 Ranger Raptor, 2013 Ranger XLT spacecab
Vehicle fleet engineer
Any codes? There were some issues with the MAP sensor I think, and potentially the fuel rail pressure sensor
