Look, I made a huge HAI
jdamtb918
Jon
Tulsa
2021 Ranger Tremor
HVAC Tech
Please tell me Mr LO33’s decided to put this into production and someone is willing to throw this beggar a link…?
Deleted User 38384
Like he said, it's a joke. Unless you move the air filter out of the engine bay, it's always going to be sucking in hot air from under the hood. Intakes that use the stock lower box try to combat this a bit by using the stock "scoop" that pulls from the front edge of the hood.
I know this was a few years ago but I tried something (that seemed to make sense to me). I wanted my cake and wanted to eat it too...
I carved up the stock intake snorkel so it would blow directly at the air filter. The modified snorkel presses against the Injen trim seal so all the air coming in from the front edge of the hood is funneled to the bottom of the air filter.
As far as "turbo sound" is concerned... I have an abundance of it. It's one of the 1st things people comment on when I give them a lift. Any time I point my toe,,, it gets loud. You can hear it sucking air like a leaf vacuum. My truck screams like a Raped Ape !
jdamtb918
Jon
Tulsa
2021 Ranger Tremor
HVAC Tech
Are you just running upgraded charge pipes or do you have an intercooler as well?
Wish I could get a unbiased answer to which CAI offers the most benefits between the Injen and S&B.. Info on the performance of the S&B for our trucks specifically is pretty scarce I've found..
Deleted User 38384
I'm not familiar with the S&B. I had the Roush CAI 1st. Did not notice much of a gain over the OEM air box with the Roush but I wanted it on the truck for looks. But,,, performance always beats looks so I switched to the Injen. LOVE IT !!! You can hear it sucking in air like crazy.
I have the CVFab Intercooler with the CVFab Hot & Cold Charge Pipes. Along with the CVFab catted downpipe. Stock midpipe. Roush catback. And Revolution Automotive tune.
Loweredon33s
Loweredon33s
Baltimore
2021 Ranger
Performance person
Unless you’re trying to make over 350 wheel horsepower then it’s not going to be a factor. Pick the one you like. Injen makes more noise but some people have a problem with it because they are afraid of hot air ?
The S&B is amazing, I was even visited by their rep at our shop yesterday, they make a nice, versatile product. I’ve dyno tested Mishimoto (similar to closed S&B) Injen and my 4” custom made open intake. They all made the same horsepower on my truck at 316rwhp with Injen and my 4” being highest. The graph is a full bolt on truck with stock turbo on 93. No tune changes were made and the baseline is the stock intake. I believe Mishimoto was in the middle.
jdamtb918
Jon
Tulsa
2021 Ranger Tremor
HVAC Tech
So I took inspiration from your posts and went with an Injen CAI. I love the new noises my Tremor makes! You mentioned
I don’t believe in the stock intake, it might be cooler but it is quite restrictive and turbulent. All intakes tend to heat up at lower speeds (some more than others)
I wouldn’t rock crawl with an open intake but for daily driving and overall performance I think they work great. The heat goes away rapidly and doesn’t seem to have much impact on power. I have had stock, Mishimoto, Injen and now my own design. The open style intakes are a little warmer but they move air so much better than closed and they cool right down once you’re moving any volume of air. I let my truck idle with the hood down and then again with it up yesterday, interestingly the the temperature was similar in both tests.
Also good to note that the tune doesn’t really care about the intake temperature, it uses the intercooler temperature as the guide to timing control. I have an intercooler and it’s definitely working, my charge temps are rarely over ambient when moving air and are always lower than the IATat low flow/load.
So I have an OBD Link MX installed so I can monitor transmission temps as well as IAT. How are you able to monitor your charge temps? Is there a PID specific to that?
The Charge Air Temp - is read by the MAPT (Map Sensor with integrated Temp Sensor) and is PID displayed as IAT2 (Intake Air Temp Sensor -2)
jdamtb918
Jon
Tulsa
2021 Ranger Tremor
HVAC Tech
thanks for the help! So I’ve got Intake air temp sensor 2 pulled up thru my OBDLink MX+ and reading on one of my gauges right next to my intake temp #1. I recently installed the Injen CAI on my Tremor. I’m noticing at times in traffic that sensor 2 is reading higher or the same as sensor 1. I was hoping there would be a greater Delta between the two but in the opposite direction regarding those temps.. Is that normal?
I have never really monitored my iat2 - while driving and have some (Live Data) samples for reference but only at idle.
But I suspect you are seeing heat soak from the charge pipes and intercooler, since a CAI is only lowering the IAT before the Turbo & Intercooler.
I think even at cruise - with only the CAI you may only see about 5 degrees lower IAT2 over stock as you are still using the stock intercooler.
So in traffic - stop and go etc - you do not have any ram air across the intercooler and are getting heat soak from radiator, engine bay - setting on the intercooler and charge pipes.
jdamtb918
Jon
Tulsa
2021 Ranger Tremor
HVAC Tech
OK that does make sense. however, on my way to work this morning (5:00am), I was monitoring my temps and still getting a higher intake temp on sensor 2 than sensor 1. This evening I’m gonna play around in OBDLink app to see if I’m using the correct PID. I appreciate your help
What is the driving condition and what are the readings for IAT and IAT2 and also Ambient Temp?
Also is it - under boost at the time of the reading?
It falls into the job of the intercooler - its job is to lower the intake air, after the turbo and its goal is to lower the temp as close to ambient as possible, so when under boost the turbo is adding heat that the intercooler must remove and when not in boost its removing (heat soaked) air
jdamtb918
Jon
Tulsa
2021 Ranger Tremor
HVAC Tech
The conditions were normal highway driving. I had cruise set at 72mph. IAT-1 was a few degrees (83-84*) from ambient which was around 80*. IAT-2 was roughly around 88*. I didn’t think to factor in the heat from turbo. Boost was around 2 psi while cruising 72mph on the highway. With what you mentioned in mind now, I’ll pay more attention to those variables next time. Do our intercoolers need to be cleaned at some point with some type of coil cleaner or are they pretty well protected?
Dereku
Chicagoland Area
I pop off the top plastic panel every spring and hose it out, you would be surprised. Then i use the same concentrate coil cleaner on my AC condenser on the house and truck at the same time. Let it sit and spray away. Makes a big difference. Most of the over heat at longer periods of idle issues are due to this.
Your reading appear normal - but it is a good idea to visually check the fins for debris as well as in between the condenser and radiator - periodically clean the area, as far as internally - it only becomes an issue if the turbo and or PCV system has released an abnormal amount of oil into the cooler and its plugging it up. - Its normal to have a light film but not pooling and dripping heavy off of the tubes.
For the PCV System - This is where the catch can - (can reduce) that oil film in the system.
