Long Sunday read (something about tire vibration and Ford service and "franchises" sucking)
SegFault
OK
2020 Ranger Lariat
Industrial Sanitation Engineer, Cloud DevOps
I'm not sure where to start with this. Long story short, I've been experiencing intermittent vibration at highway speeds (60+ mph), for about a year. Prior to this time, there was absolutely none, even at well above highway speeds (some toll roads here are 75+ mph, and I’ve driven enough above this with no vibrations.) My truck isn't driven very much since I work from home, and most of the miles on it are either grocery / Costco runs or vacation road trips. Other than that, it's in the garage 5-6 days a week, sometimes more. This is the *short* version of the issue and what I’ve done, believe it or not. I don’t have a tl;dr version, so stop reading now if you’re not bored or have some free time.
The vibration started after I had a flat plugged in my rear passenger side tire. I found the tire completely flat in the garage one weekend, I'd run over a screw and the tire slow-leaked to completely flat. I grabbed the air pump to see if it would hold air, and it did, so I drove it over to the Discount Tire location where I'd purchased the tires, about 4 miles away, and left it with them. I picked the truck less than an hour later, drove home, and everything seemed fine, but this was all city streets at speeds of 40mph. I didn't notice the vibration until a week or so later when I went across town via highway.
The vibration started a little above 60mph and continued up to 70mph and higher. I figured that when I'd had the flat plugged that my local Discount Tire must have rebalanced the tire wrong after the repair, something that this particular Discount Tire location has a history of doing. So, I did what I'd done in the past to get incorrectly balanced tires fixed, I went to the next closest Discount Tire store that had always resolved the balancing issues caused by my local store. Except this time, when this store checked the balance on the tires, they were all correct -- something that had never happened before. I explained the vibration issue, what the other store had done (plugged a flat tire), and they agreed to rebalance all of the tires for me because of the known issues and history of tire balancing with the other store. Even after this, the truck still had the same vibration issue, mainly in the seat, but some in the steering wheel.
Since I was due for an oil change anyway, I decided to get a second opinion on the tire balancing and made an appointment with the Ford Dealership that I normally use. This dealership, which I'll call "dealership A" is one I'd used in the past for minor parts (tailgate letters, floor mats) and prior oil changes.
And this is where things turn into a complete Ford dealership shitshow, with the "we're all franchises" excuse to do the bare minimum amount of diagnostic or any other work. I told dealership "A" that I needed an oil change, told them the story of the vibration and the number of times I'd had tires balanced at multiple Discount Tire locations, and said that I needed them to check and rebalance the tires if needed. When I picked the truck up, I was told that they "found rear tires to have possible have torn inter belts, all tires balanced to zero" (this is the exact quote from the service invoice.) I took this write-up back to Discount Tire, the location that always seemed able to fix the balancing issues, and they told me that what was written (“torn inter belts”) wasn't actually a thing (obviously), and that if that *were* the case, that it would be clearly visible on the tires. They agreed to pull all tires off of the wheels, remount, rebalance (force road balance), and let me try from there. I saw this entire process and they showed me the whole process, including the balancing. I left, went home via highway, and still had the same vibration issues. I was leaving on a road trip to Colorado in a couple of days, so I had to live with it.
The road trip clarified a few things about the vibration: It was intermittent, sometimes feeling like I was running over a gravel washboard, other times just a slight, still present vibration. It seemed the worst when decelerating on the highway going downhill, but this wasn't always the case. The speed didn't seem to matter either, the same vibrations varied from speeds between 65-85mph, with no consistency. I decided I'd be headed back to Ford when I got home, because given this behavior, how could it be the tires?
So I went back to Ford dealership "A", and told them the symptoms of inconsistent vibration, and asked them to check and perform an alignment if needed. I also asked them to check the suspension for anything that might be off. And this is where I got the "franchise" dealership nonsense: I was charged for an alignment, it was slightly out of spec on the camber and toe, but nothing off enough to cause the vibrations that were still occurring. And THEN I was told that dealership "A" could not diagnose anything suspension related because the suspension was not stock. I pointed out that the suspension is a FORD suspension installed by a different FORD dealership in town (Ford dealership "B") and that they'd just performed an alignment on this "not stock" suspension, but couldn’t do diagnostic or troubleshooting work on it? I was told that they're a "franchise" and that they don't really work with other dealerships and that I'd need to take the truck to dealership "B" to have the suspension check / diagnosis performed. They also said, and again I'm quoting from the service invoice, "inspected drive line. found drive shaft wobbling". I pointed out that the drive shaft wasn't and isn't part of any FORD suspension kit and is obviously stock (if they looked) and they said I'd need to have dealership B diagnose my issue.
I made an appointment with dealership "B" and explained this ENTIRE story to them, mentioning that not only would dealership "A" not diagnose anything non-stock on my truck, but that their recommended fix for my vibration issue, in order to continue troubleshooting, was to return the suspension to stock. Dealership "A" was also kind enough to provide me a price to do this work, something I declined. To dealership "B"'s credit, they didn't badmouth dealership "A", even after reading dealership "A"'s full writeup (I provided.) Dealership "B" only questioned why dealership "A" couldn't diagnose the driveline (driveshaft) issue they claimed to have found since it was a stock component. I agreed, and left dealership "B" the truck to work on.
Nearly a week later, after not hearing anything from dealership "B", I called them and asked for an update. They told me that the truck was ready to pick up, and that they had 1) found nothing wrong on the suspension or driveshaft (no "wobbling"), and had also put a different set of tires and wheels on my truck and found that with their tires and wheels on the truck, there were no vibrations, the ride was smooth. I couldn't verify this, I wasn't there when they performed the alternate wheel/tire test.
When I picked the truck up from dealership "B", I was surprised with a $165 bill for diagnostic work (I was given no estimate when I dropped the truck off, I assumed it was warranty because they installed and warrantied the suspension) and also told that I needed an alignment. I told them that dealership "A" had performed an alignment only 2 months earlier, and they told me that if I wanted them to perform an alignment, that I'd be charged for it. Dealership "B" said that I would need dealership "A" to address this, or I could pay them to perform an alignment. Had I known that using Ford parts and having them installed by a Ford dealership meant absolutely less than nothing when it came to other Ford dealerships performing basic diagnostics, let alone warranty work, I wouldn't have bothered buying any Ford parts. I would've gone with something from Icon or OME, because it would've been the same amount of effort required on my part for component related warranty work (my Fox suspension was still under warranty from dealership “B”.) And at this point, based on how Ford's dealerships operate, I'd steer anyone I know away from buying any Ford vehicle, at least until they can clean up their dealership mess because it's apparently rotted all the way through sales (see: Bronco markups and gouging) to service (my experience is likely very, very common.)
As a side note, I took my truck back to dealership “A” and told them dealership “B” had found the suspension out of alignment (enough out of spec that they wanted to adjust and charge me for it) and dealership “A” agreed to check the alignment at no charge. Not surprisingly, they found the suspension IN spec and nothing needed to be adjusted. So I likely need a third opinion here.
If you've read this far, you probably need better hobbies (I know I do), but now I'm stuck trying to figure out what to do about my tires because dealership "B" has determined that the tires are the cause of the vibrations. Discount Tire has offered some credit back on my tires towards new ones (minimal), and I mostly understand their position on this. I mostly understand because I don't have proof of defective tires, only barely passing circumstantial information from two different Ford dealerships, both of which can only be bothered to do the bare minimum of service work and then make it the customer’s responsibility for anything more. I can try to get something out of Cooper Tires directly (the tires are AT3 4S with about 12,000 miles on them in 2 years) by retelling this story, but at this point, if I'm going to be out any money on tires, I'd probably just start over with some other brand. After dealing with this all on Friday, I'm too pissed off and tired to spend any more time and effort on it. I'm already well over my quota.
Thanks for coming to my not-a-TED Talk.
SegFault
SegFault
OK
2020 Ranger Lariat
I'll admit I didn't read the whole post but have you seen this one? It may not be your tires but possibly the driveshaft.
https://www.ranger5g.com/forum/threads/one-piece-driveshaft.21381/
I saw that thread after I got back from my CO road trip and that's why I went right back to Ford. And then the whole "we can't troubleshoot this Ford suspension that this other Ford dealership installed" BS started at the first dealership. And they were the ones that stated that they "found drive shaft wobbling" but still wouldn't touch a stock drive shaft that they found "wobbling" because of unrelated and not-stock, but still Ford suspension components. The other Ford dealership said my driveshaft was fine after they had the truck a week, but seriously, I trust nothing these asshats do or say anymore after this latest round of BS. And I haven't even written up the story of my passenger side window motor replacement yet..
Muddy Fenders
Judd
Canada
There's nothing wrong with going to an independent mechanic that wants your business. If your Ford dealers aren't meeting your expectations, then walk away.
The tire sitting flat could very well have damaged the carcass of the tire. that's a lot of weight on the edge of the rim/rubber.
I also agree with a center bearing issue on your driveshaft.
Potentially both are causing your grief.
SegFault
SegFault
OK
2020 Ranger Lariat
Yeah, finding a local mechanic / offroad shop to have a look is next. I've already got conflicting alignment data from both dealerships, I don't believe anything either of them say at this point. I at least need the alignment confirmed for whatever tires I end up with.
Joeiconic
You we’re right about the “long read” part. I’m waiting on the cliff notes.
cooper is a stand up usa based company and makes many of the tires they brand in the states and will take care of you if its something related to tire failure. also if you have the road hazard warranty from discount they may replace it for you. id contact discount first if you have the warranty. if not talk to cooper. tires aside, my bet is the center support for the drive shaft. its been a known issue that dealers have been trying to evade since the 5g hit the lots. for reference on dealers they do not care half a jar of wizz what happens to you or the truck no matter what extended gold ford bs warranty you purchase or even if you got the truck and warranty from them. the worst part of owning a ford is the ford dealers. you can contact ford customer care etc. and they will jerk you around for a few weeks, lawyers and court dont scare them in the least. fords warranty serves no purpose other than a sales tactic unless the dealer stands with ford on the warranty and is honest. in my experience that does not happen. just a tiny soap box add on here - even if dealer A or B would honor the warranty and do what they are supposed to do - would you want the folks that just lied to you and jerked you around working on your truck... i would not.
Chris M
Surprise, AZ
2021 Ranger XLT Sport 4X4
Security Supervisor
Not sure if this'll help you feel better about what you're doing or not, but here it is anyway:
I put the Ford/Fox level kit on my 2019 2WD XLT...bought and installed through a Ford dealer. Loved it very much...for awhile...until I had to put new tires on. I admit going up one size in tire, but did buy a similar type all season to the stock tire. Shortly after that I began to get a vibration between 55-70 mph. Ford could not/would not figure out the issue. Claimed no vibration. Tire shop tried working with me but also could not diagnose the vibration cause.
Ultimately I traded for my '21 4WD. No vibrations so far.
I've often wondered if the leveling kit didn't cause something ELSE to go bad or come so out of adjustment as to cause the vibration.
I hope you get it sorted as I understand your frustration.
JasonTremor
2021 Ranger Tremor XLT
So no vibrations prior to having the flat and getting it patched/plugged? If so, I would be suspicious of whatever poked the hole happened to damage one of the steel belts. It would balance out on a balancer, but would no doubt still generate a vibration. Throw your spare tire on to replace the patched tire and see if the vibration goes away.
JasonTremor
On the road force balancing, you would need the lbs of force measured by the balancer for each tire. That would tell which of the tires is running amuck. Good explanation in the video below.
SegFault
SegFault
OK
2020 Ranger Lariat
And this is exactly it. These two dealers can't even agree on alignment numbers I literally went directly from Dealer B who told me there was no vibration with a different set of tires on the truck (I didn't confirm, they did this without me riding with them) over to Dealer A, who showed different alignment numbers on their machine. I'm pretty sure I didn't run over 10 or 12 curbs or potholes at 65 miles per hour when going from one dealer to another, but maybe I did. After all, they "couldn't confirm what might have happened since they performed the alignment" (paraphrasing Dealer A.)
bRaptor
Ward
USA
2021 Ranger XLT tremor
@SegFault I read your whole post. You mentioned the tire was completely flat and then aired up and plugged. Have you put a full size spare on the same wheel and tested it close to that speed? Is your wheel aftermarket? Sometimes slight imperfections show up at higher frequency / speed. I'm saying what if there was some slight wheel damage that led to other wear in the bearings. Anytime someone claims something on a service report, I would make them replicate it for you.
SegFault
SegFault
OK
2020 Ranger Lariat
There were vibrations prior to the plug when the tires / wheels were new -- all related to incorrect tire balancing. The Discount Tire I purchased the wheels / tires from was kinda known for not being able to balance tires. The alternate discount tire store I use now fixed this for me and the truck was completely smooth and normal for over a year. Everything went to shit after the tire was plugged, so I really should try your suggestion, maybe with a couple of new tires in the rear. I just don't want to shell out the cost of two new tires on a gamble that it _might_ fix the issue.
good video, ive never seen how the road force balance is done.
SegFault
SegFault
OK
2020 Ranger Lariat
Yeah, that's what I wonder too. And it might be something a competent independent mechanic / offroad shop could tell me, assuming I can find one. Looking for an independent mechanic isn't something you normally would need to do for a truck with a year left on the regular 3/36,000 warranty.
