List Of Deleted Items
philanderer
land of oz
'22 ford ranger cactus scab
apparently wiper fluid should be added to this list. the low fluid indicator came on in my truck today. had it less than 2 weeks and only sprayed the fluid 2 or 3 times. reservoir took almost a gallon, so yes, it was breathing fumes. nice quality control job, ford.
AvockAdoo
Sam
Denver, Colorado
2020 Ranger XLT
Big annoyance here on most manufacturers. When the light comes on for washer fluid, you'd damned well better be able to fit a whole gallon in there. I hate having 1/8 of a gallon left and needing to keep that big jug around.
Of course, ford is like most others. You can fit 7/8 gallon into the tank when the light comes on...
Jbrubakerjr
Woodstock, GA
2022 Ranger Lariat
I had the same. Only it was on Day 2 that mine came on. Must be just above the level to keep the light off, and sloshing around triggers the sensor. And yes, agree on the size of the reservoir. If it were just a bit larger the entire gallon could go in when the sensor comes on. Maddening.
stufus
Maine
2020 Ranger XLT, 302a, Technology Pack, FX4
I believe power seats (XLT 302a / Lariat) were changed for 2021.
2019 - 2020: 8-way power driver and passenger seats
2021 - 2022: 8-way power driver and 6-way power passenger seat
Deleted member 15875
'cause that saved them $0.50 on each build, yet that along with deleting other "dollar items" (PRNDS light, paint to match tailgate handle, etc., etc.,) makes their 2022 - 2023 trucks look as advanced as my 2003 Taco was.
On dirt bikes, the brands stopped adding plastic rear disc gaurds, which used to come on all dirt bikes....the mounting holes are still there.
That would be on the dealer I believe. Washer fluid is supposed to be part of the PDI process but commonly gets missed (just like tire pressure).
Jbrubakerjr
Woodstock, GA
2022 Ranger Lariat
Well, my dealer got the Tire Pressure, but did not get the Washer Fluid.
Mine was the other way around - I had a full bottle of washer fluid but tires at like 42 PSI
Since there are many different threads on this I feel it's now worthy of a sticky. Just hit the edit button on this post to add any new additions so it keeps this thread updated.
1. no rear folding headrest
2. no hood struts(as of 2022)
3. no PRNDS light
4. no glovebox damper
5. no RANGER embossed into the Lariat seats
6. no console (pen) cubby
7. no 12V outlet in the console without 110v option
8. no bright trim rings on the 12v covers that matched the radio knobs
9. only 4 bed tie downs instead of 6 (as of mid 2019??)
10. no engine cover
11. no owners manual cover
12. Eco badge on tailgate
13. no plugs in the rocker panels
14. no ignition bezel (has always been missing)
15. steel front fenders (aluminum before) estimated after March 2021 and all 2022
16. no bright button on parking brake
17. no color keyed tailgate handle on Lariat just black plastic without chrome pkg.
18. no aluminum spindles, they're now steel
19. rear passenger doors no longer have external touch lock
20. front seat headrest tilt adjustment
21. (2) 4.2" productivity screens instrument cluster replaced with (1) 4.2" screen in Lariat 500A
22. Floor Mat mounting tabs on passenger side
23. no small cubby inside glove compartment to hold owners manual
24. no removable rubber pad at the bottom of the cup holder
25. no removable rubber mat inside the console storage area
26. Eliminated Auto Start/Stop feature ($50 credit)
27. Eliminated LED headlights on Lariat Trim ($500 credit)
28. Eliminated rear differential drain plug.
29. Transmission fluid.
The attachment contains model year timing of eliminated features.
Amended...#29... ?
Jedadiah
Jed
Central Kentucky
Former '21 SuperCab Owner
Almost no washer fluid was standard on the '21's as well.
Jbrubakerjr
Woodstock, GA
2022 Ranger Lariat
