Light Bars??
  • Thread starter Deleted member 773
  • Start date
  • Watchers 38
Deleted member 1634
I'm not sure if anyone else has seen these new Diode Dynamics SAE compliant lights. They have both pods and bars. As someone who doesn't do a lot of hardcore off-roading, and 0 to none in the dark, but who wants extra light to compensate for the lackluster XL-XLT halogens, these are the types of things I've been looking for! Seriously considering swapping my old Warn Halogen pods (which only work maybe half the time now) with either or both of these. Maybe one type in yellow, the other in white.
Pods
https://www.diodedynamics.com/stage-series-3-sae-dot-white-sport-standard-led-pod-pair-1.html
Bars
https://www.diodedynamics.com/stage-series-led-lightbar-kit-for-2019-2020-ford-ranger.html
Fawnbuster
Indiana
Retired 34 years as LEO
For the folks still struggling with light bar brackets in the front that cannot block the radar unit. I've had this on for quite some time with no issues. It's sturdy, comes in different sizes and multiple holes for different types of lights. I have a 30" curved light bar on mine from Rough Country.
https://www.ebay.com/itm/162694156475
do you have the adaptive cruise and radar?
Fawnbuster
Indiana
sorry forgot to add, can you post or send a pic of how you mounted that light bar on the ebay bracket please? Most light bars i have seen mount on the ends
Hey Mike, They have a similar bracket on Amazon. It has slotted holes across the top to mount the bar on it. Here are two different ones. Oh,it doesn't interfere with the ACC because it's above it but they do have a relocation bracket for the ACC if you want to add a light bar below.
https://www.amazon.com/dp/B01D609V7...olid=23F2DD1VHYN09&psc=1&ref_=lv_ov_lig_dp_it
https://www.amazon.com/dp/B075CHHWX...olid=23F2DD1VHYN09&psc=1&ref_=lv_ov_lig_dp_it
EDIT:
Here's the relocation bracket. I don't know why they show a bumper but it's the right part and number.
https://www.carid.com/fab-fours/ven...e-control-relocation-bracket-mpn-m5350-1.html
Also here's the original post for it.
https://www.ranger5g.com/forum/threads/fab-fours-acc-relocation-bracket-installed.5811/#post-96686
Fawnbuster
Indiana
Pods
Bars
do these block the acc? or do you not have that equipment? the linked webpage doesnt say anything about the acc.
Deleted member 1634
The pods definitely won't affect the Adaptive Cruise Control. The bars might. I don't have the Adaptive Cruise, nor do I have any of those lights yet. To be safe, I would probably just go with the pods.
You could always send them a message and ask to make sure.
Fawnbuster
Indiana
EDIT:
thanks! On one hand I don't want to mess up or jack with having to move the acc , i like the license plate brackets ALOT! but my one worry there is the automatic car wash, will the license plate bracket cause an led light bar to stick out too far and get damaged or destroyed?
I like this light, amber and white - https://extremeledlightbars.com/x6s...gle-row-led-light-bar-11400-lumens-combo-beam
I don't use car washes but I can see it being a potential problem. Maybe John or someone else who's had this can comment on this?
BHunted
Sumner County, TN
If you look at the pictures of bracket, there are multiple holes. My lights are slotted on bottom and can be moved in their own tracks. Side brackets wont work unless they fit the bracket. If you search ebay, they have even a bigger one.
Fawnbuster
Indiana
yes Sir you are correct, it is the light bar i am interested in buying that does not show the bottom, i plan to buy both the bar and license plate bracket and if need be i will make an adapter. Just getting ready to start swapping the fascia piece and run wires for the brake controller. I have the wires and shrink tubing, i just ordered some of the butt connectors that combine the solder and shrink tubing
Fawnbuster
Indiana
Hmmm...I'm confused...
https://www.taylorsvilletimes.com/2...l-prohibit-use-of-light-bar-devices-on-roads/
Quote...The bill language states that “no person shall drive a motor vehicle on the highways of this State while using a light bar lighting device. This subsection does not apply to or otherwise restrict use of a light bar lighting device with strobing lights. For purposes of this subsection, the term ‘light bar lighting device’ means a bar-shaped lighting device comprised of multiple lamps capable of projecting a beam of light at an intensity greater than [25 candlepower].”
Does "operating" just mean having the lights on or have them mounted? 25 candlepower?! A good lighter can do better than that lol...
Having them on.
Fawnbuster
Indiana
Does your light bar have mounting brackets on the bottom? Have a link?
BHunted
Sumner County, TN
Yea, not crazy about those butt connectors with t
