Diode Dynamics SS6 light bars wiring
Schlemy
Dan
Crystal lake IL
2022 Ranger Lariat Tremor
AMT
I have a 22 Lariat Tremor. I purchased a Diode Dynamics two SS6 light bar kit for a Ranger It came with a harness which has a relay and switch. It also has a wire to eliminate the switch. I wanted to know how to wire it to a Upfitter switch. Can I use this harness or Should I return this harness and purchase the one without the relay since my truck already has a relay? Thank You in advance for your help Dan
EJH
Ed
Subarus, 2021 Ranger
I have the same lights bars, and they are great. However, I can't answer your specific question because I don't have a Tremor. I used the DD harness and relay.
jmelair
Rockledge, PA
23 Ranger XLT Tremor
Ford left the leads to the "upfitter switches" in the engine compartment, on the right, near the relay box, 6 leads, 1 per switch (all this is in the owners manual, pages 409-413 btw). Connect the 'hot' wire to the appropriate lead at the fuse block under the hood, connect the ground to the frame somewhere (bare metal) and you should be set, so I think you should be able to return the relay kit. Good luck!
