LED Lights and Blinker Speed
You should still be able to customize with Forscan - to add the turn signal as DRL
I did not mess with moving - customizing
Might just have to play with it - I’m quite sure it can be done.
I drive with marker lights manually turned on all the time...problem solved...my DRL are dual 6" light bars in my grill...all combined makes my truck more visible for safety...
As I've mentioned before I have my DRLs on my XLT set to be my fogs. This was done in Forscan. I've also added my parking lights to my DRLs so my marker lights and taillights are also on and I can leave my switch in Auto. I also have switchbacks so my turn lights flash amber and my parking lights are steady white. There is a turn lamp setting in Forscan but that may disable the dedicated DRLs on the Lariat lights. Might be worth play around with.
Synfulz
Richard
Philippines
2020 Ranger FX4 Diesel :)
Retired Powerplant Operator
I installed both led headlights and taillights, and my left turn does hyper and right is normal. So I know by sound which one is on. ?? A good reminder if don't auto shutoff.
philanderer
land of oz
'22 ford ranger cactus scab
I used the LASFIT Canbus Ready 7443 led bulb 7444 Error Free 7444na Switchback for Front Turn Signal bulbs and there was no hyper flash on the outside or on the dash.
thanks for mentioning these. very bright, and as you stated, no hyperflash
Torrsall
T
SoCal
2021 Ranger Lariat 4WD
these? they work even though amazon says otherwise? thanks!
Can confirm in my 21 Lariat that the Oxilam 7440 with built in load resistor work flawlessly! Cleaned up the hyperflash in the cab and a Canbus created problem with the overhead maps lights (one wouldn't turn off). Good stuff but they do run pretty warm.
lukdeg
Luc
Edmundston
Ford Ranger lariat 2023 Cactus grey
paramedic
There are numerous threads on adding LED's and I think the error free ones are what you need, if you know the brand, just use the search bar here and i am quite sure you will find the specific install notes on them. I have the LED taillights as well but installed thses in my front turns and no issues with hyper-flash.
OXILAM 7440 LED Bulbs Amber Yellow 4000LM for Turn Signal Lights with Build-in Load Resistor CANBUS Error Free T20 7440NA 7441 W21W WY21W Blinker Bulb Replacement (2PCS)
Visit the OXILAM Store
4.4 out of 5 stars 4,102 ratings
| 195 answered questions
#1 Best Seller in Automotive Vehicle Top Clearance Light Assemblies
-17% $24.99$24.99
I have those as front signal light and they are bright as hell!!! love them!!!!
