Latest TSB for the 10R80
Stevedbvik1
2022 Ranger Tremor XLT
Ford has updated the TSB for the 10R80. It’s no longer 24-2101 and is now 25-2024.
Here’s a link to read it ( nothing available to copy yet)
https://www.ford.com/support/service-information/
Either put your VIN in or year/model info. It’s the first TSB listed that mentions 10R80.
They’ve developed a extensive testing procedure to check the CDF for leakage. Also the verbiage for replacing the transmission under LTIS is gone
Vr22s
Ryan
Draper, UT
2021 Tremor
Biotech Production/Operations Manager
I'd be curious if they would service a transmission that has slight symptoms of this but isnt throwing codes.
Or at least do a diag. on it under this pretense.
Stevedbvik1
Stevedbvik1
If you’re under the 5/60 powertrain warranty or have an ESP then the answer would be yes. Codes aren’t required to proceed with the testing. Shifting complaint is enough. The TSB just requires to have one or the other.
Vr22s
Ryan
Draper, UT
2021 Tremor
Thanks for clarifying
jflogerzi
Moreno Valley, CA
this is correct. got my transmission replaced. no codes.
OldHippy
Michael
Central Ga.
2020 Ranger XLT 4X4
I have a question. I purchased the extended dipstick from Mikes. Should I wait to install it till after getting transmission checked?
Stevedbvik1
Stevedbvik1
I would wait until after it gets checked/repaired. Not that it should be an issue with the dealer ( you can ask) . It would be better to just let them do their thing and then you can install it. I installed mine before any transmission work was done and it wasn’t an issue. But it was a couple of months before I brought it in to be checked out.
OldHippy
Michael
Central Ga.
2020 Ranger XLT 4X4
Ok. Thnx. I just didn't want them to try and say my alteration caused the issues with the transmission. Ya know how some folks can be about stuff like that. Thnx again ✌
ccasanova22
Lakeland, MN
2022 Ranger XLT Tremor
It looks like the new procedure to determine if the CDF has shifted is a step in the right direction.
I’m so glad I got mine fixed - the new CDF and valve body repairs made it like a new truck.
Now it isnt stuck in 8th going up hills (down to 20-30mph) and drops a gear when necessary, no squealing of tires on shifts, and no slipping where the RPM flies up and then it “catches”.
For those on the fence, get this done before things get worse. It’s only a matter of time.
Stevedbvik1
Stevedbvik1
Preach
Vr22s
Ryan
Draper, UT
2021 Tremor
I might just be paranoid at this point, I dont know if mine really needs it. Seems like the transmission is sluggish at times and does a weird shift here and there... but nothing that seems serious.
Im still under the 5yr/60k,
Stevedbvik1
Stevedbvik1
Mine was never serious. Subtle shift quirks and never any codes. 2022 with 18000 miles and I have a new transmission. If you have any shifting issues even subtle the latest TSB now has a test procedure to confirm issues.
