My Saga With The 10R80 (Will Update)
THPOOKYCAT
Keegan
Spencer County Kentucky
2021 Ford Ranger XLT FX4
Ford Motor Company Inspector (KTP)
So this is gonna be a long one. Buckle up.
First off, I've worked for FoMoCo at two different plants in KY for over 13 years.
My 2021 Ranger XLT FX4 started having pretty severe rough shifting issues around 35,000 miles. I took it to the dealership where I purchased it, and they told me that was the nature of the trans, but that there was a strategy update. The update was done and the learning module tables were reset.
Around 45k, the problems were right back, as bad as ever. On top of that, the trans dropped itself into neutral when I was trying to get out of a parking lot fast in heavy traffic. Hit the gas, heard a bang, rolled forward. Stabbed the breaks, and had to put it in park before it would go back into drive. Really lucky I didn't get hit. I I did some research and found one of the TSB's (not the most current). I called the original dealer, and was told that they wouldn't even be able to look at it for 4-6 months. I drive a lot. I knew I couldn't wait that long.
I called another dealership closer to me that came recommended. Took it in with a copy of the TSB, and gave them all the info on what was happening. They had it for a couple of days, and called me saying that they installed a new strategy (again) and reset the tables.
Around 2.5k later, the same problems and then some new ones. The shifts were harder, and the trans was hunting for gears. It didn't want to go into 10th, like it was stuck in 9th on the interstate. It would also stay in 10th and "lug" at low speeds (around 30-35mph). Stop and go rush hour traffic was a nightmare. Sudden stops would cause it to slam into lower gears, and sudden acceleration would do the same.
Took it back to the 2nd dealership, explaining what was going on. They performed the second step of the TSB (replacement/repair of the Valve body assembly). Along with clearing the tables for a relearn.
During all previous relearn periods, the truck shifted reasonably, definitely not smooth, but acceptably. This time was different. After around 500 miles, the trans started slamming into gears worse than before. Not as frequently, but significantly more violent. Also, the truck dropped out of gear into neutral again.
Back to the same (2nd) dealership. Two of the service writers stared at their PC monitor for around 10 minutes while I stood there waiting. Finally, one said "well the truck isn't showing any DTC's and we can't replicate your symptoms, so there's nothing we can do." I had already talked through the most current TSB, to make sure they knew about the next step. The updated CDF drum and bushing.
I asked if the truck had shown any codes before, and they said no. I asked if not, then why had they removed the valve body and reset the tables. They told me because they knew about that issue, and it was a courtesy. They claimed that Ford wouldn't pay for the warranty work without DTC's/replicated symptoms. I left the Ranger there.
I called the Union Dealer Liaison rep at my plant, who told me to call the Detroit Quality Claims Office. After a 45 minute conversation, the only thing they could tell me to do was take it to a different dealership. The whole TSB process would have to be started over.
The very next day, I get a call saying my truck was ready to be picked up. I asked what they had found and done. Their response was that they AGAIN resent the learning tables, the trans tech couldn't replicate my symptoms. I drove to the dealership, a conversation over the phone wouldn't cut it.
They said there was nothing else they could do, there were no DTC's and they couldn't replicate my symptoms. I argued with them for around 40 minutes, got nowhere. I told them to give me the truck, was left standing there, and then told by a different service writer that they were having trouble finding my vehicle. 15 minutes go by. Finally they found it, left with the paperwork and keys in the driver's seat.
The service writer who drove it up could tell that I had completely hit my limit, and told me that he himself felt it shift hard driving it through the lot. He gave me his cell number, and told me to text him through the weekend with updates on how it was driving.
Next day, the wrench/powertrain light pops up on the IP, and the truck won't go over 55mph. It's slamming into gears like someone is hitting it with a sledgehammer. Notifications are popping up on my phone. I text the service writer and he tells me to bring it back in.
I drop it off, get a call two days later, and the wrench/powertrain light is gone. No DTC'S. Symptoms can't be replicated. They resent the tables as a courtesy.
I show up at the dealership demanding to talk to the service manager. He has no answers. Nothing he can do.
A few days later, the wrench/powertrain light AND the check engine light turn on, and it goes into limp mode. AutoZone scanner shows code P0235.
I take it to another dealership (3rd). They won't even look at it because someone else has worked on it.
It's now sitting at the original dealership where I bought it, having to start the whole process over.
I have less than 5,000 miles left on the powertrain warranty.
I'm a 13 year Ford employee, and I can't even get known issues covered under warranty for a known part failure under a TSB. God help a regular customer. This is the last new Ford I'll ever buy.
***UPDATE*** For anyone whose interested.
Spoke with my union dealer liaison rep again. I asked him to look up my VIN# in the Oasis System (apparently they can access it). I had him check for codes/DTC's over the past few months, as the dealership (#2) told me they couldn't see any. It turns out that they were flat out lying to my face. It has been throwing codes multiple times a week, but no warning lights or notifications to my phone through FordPass.
I called the Detroit Quality Claims Office again yesterday, to update them on the continuing situation I'm in.
I wanted to have it on record that dealership #3 refused to touch the truck, and gave them the service managers reason for refusal. The DQCO rep proceeded to talk over me, and accuse me of not letting dealership #2 do their job (as they are qualified mechanics and I am not). The rep didn't say anything about dealership #3 and their refusal, even though I explained that they (DQCO) instructed me to take the truck to a different dealership, because "some dealerships are better than others". I also explained that every time (except for once) the dealership (#2) told me to take the truck home, as there was nothing they could do. The DQCO rep then told me that our conversation was becoming "unproductive", and hung up on me.
I want to state that not once during any of my conversations with DQCO did I raise my voice, curse them out, or become belligerent in any way.
Lost In The Ozark's
Wow that's insane that you had/have to go through all this! You would think most if not all of the dealers by now would know about the issues the 10R80 has and would be (somewhat) knowledgeable on how to fix it. I hope they finally take care of you this time and it's sad that even a Ford employee can't even get good customer service today. I will say you have a lot more patience than I do because by now I would've lit it on fire in front of the last dealership and walked away! 🔥 Good luck!
I'm a 13 year Ford employee, and I can't even get known issues covered under warranty. God help a regular customer. This is the last new Ford I'll ever buy.
GAAAAAAAAAAAAAAAHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH........GET ME OUTTA HERE................
Fordup
Ed
NY
youtube.com
Retired YouTube Creator
May be worth filing and NTSB report about it shifting to neutral when pulling out into traffic and not being fixed after that. Seems I have read your not the only one this or something similar has happened to.
shovelhd
Cape Cod, MA
2021 Ford Ranger Lariat
retired electrical engineer
I had a similar experience when I brought my 2021 in for HVAC blend door issues. The service writers said pretty much he same thing as yours. If there's no codes, Ford won't pay for it, and the dealership would have to eat the time. Even though both your issue and my issue do not always throw codes, the dealership doesn't care. They are not going to get stuck with the bill for diagnosis. That was their priority, not the customer. When I spoke with the service manager, he basically said that I will have to wait until something breaks before they will fix it. In my case. it's a pain in the ass. The HVAC is still clicking, and it won't hold temperature properly. In your case, you could get killed.
My 10R80 is acting up when cold. It does seem like it's getting worse. Good luck to you getting your transmission fixed or replaced.
THPOOKYCAT
THPOOKYCAT
Keegan
Really poor dealerships these days.
Yep. Piss poor dealerships, designs, customer loyalty... And I guess there's nothing Ford can do to get dealerships in line, if they even care. The fact that there hasn't been a recall on the CDF is disgusting. There's a reason the parts were updated in 2022, and that they switched to the 10R60 in 2024.
THPOOKYCAT
THPOOKYCAT
Keegan
Thanks man. I've figured out that the dealerships do know about it, they just don't give a shit. They don't get paid as much as they want for big warranty repairs because they're flat rate. So they do the small jobs in half of Fords allotted time, and come out ahead. The only way they want to gut a transmission, is if they can charge as many hours as they want, and the customers is the one paying. At this point my patience is gone. More serious actions are going to be taken soon.
2021 XLT 4x4 Sport, 1995 Harley XLH1200
Are all the dealers you have visited independent? Around here in central Va. there are several dealers that are all owned by the same people. Just curious.
THPOOKYCAT
THPOOKYCAT
Keegan
Thanks. In all honesty, even if they do rebuild/replace the trans, I've pretty much lost all confidence in the truck. On top of the trans, now the turbo may be toast. I've been borderline fanatical with my maintenance routine. Full synthetic oil changes and premium filters every 5k. Air filter and tire rotation every other oil change. I bought an OBD2 monitor to watch fluid temps. And even still everything major seems to be killing itself.
THPOOKYCAT
THPOOKYCAT
Keegan
Doing that tonight after work. I'm also going to be joining one of the class action lawsuits, but I need to do more research first.
