Jeez, how can this be?
Mark W
Woodbury Mn
2012 Jeep Grand Cherokee
I was hauling river rock the other day and had it loaded at the rock place. Was on my third and final haul and had a new loader. Asked him to be careful as the first two loaders did a great job. This guy was very careful but when he first started dropping the stones into the bed, a few got in between the rear of the cab an the bed. Probably 15-20 small stones trapped in there. Any suggestions on how to remove them?
Also got some small pebbles and dirt into the tailgate as well. I figure these will eventually work themselves free or I could remove the tailgate and shake them out.
All advice is appreciated.
Thanks -
FULLSCALE
Adam
Ontario, Canada
I used a yard stick to pop out the bulkhead plugs before taking the truck for Line-X. Maybe you could get one in there to push/lift them out?
Fawnbuster
Indiana
Retired 34 years as LEO
If all else fails, a thin stiff board and lay under the truck and press them up and out?
Glocker
Boca Raton
If they're jammed in between the front of the bed and the rear bulkhead, you might try flexing the truck on an object to get them loose.
Augie81
I can't offer any advice to fix your issue. However this thread made me think of an idea to prevent something like that in the future for cheap. I bet you could get one of those pool noodles and cut it in half lengthwise. Then wedge it in between the bulkhead and the cab before being loaded. That should prevent any debris from falling in. It might look a bit silly but I think it would work. :)
Ace Holliday
Scott K
South Kalifornikstan
2019 Ranger XLT Super Crew
Better jump on this new business opportunity or I will. Laugh now but just think of how much money the guy made from those little umbrellas you put in your tropical drinks. ?
Mark W
Woodbury Mn
So I have tried a bunch of different ways to get these rocks out. All to no avail. I did manage to get a bunch of other crap out of there. It no rocks. I think the way that may work is to take a vinyl coated hanger and put some foam around the end going down to the rocks. This way the foam can fill the space between the cab and bed as the stones are being lifted out.
I did get all the dirt and stones out from the tailgate. Small victories.
Keep the suggestions coming
FoD
Terry
Out There
Retired & Grandparenting 🤣
Thinking there is a way that combines the pool noodle and tailgate damper and be combined for the new bed/cab conveyor for moving stuff out from the space...?
FoD
Terry
Out There
Something like this lol!!
geophb
Mechanical Engineer
Could always pull the box off or unbolt it and move it some
THLONE
Thom
Tucson,AZ
internet wise guy
put a bike tube between and air pressure should slightly spread the opening to get the rocks out.
Mark W
Woodbury Mn
How hard is it to unbolt the box, move it a bit and put it back in place?
