I need a way to store my topper
r1ch999999
Rich
Nashua, NH
Software Engineer
Ok, so let me start by saying I thought I'd be able to take my topper off when I didn't need it, but it turns out it's a lot heavier than the one on my Sport Trac. I'm looking for a way that I could take it off and store it somewhere. I could easily make some saw horses that would help, but what about one of those Jeep hard top rigs? Think those would suppor the weight?
HenryMac
Mech. Engineer - Retired
That could work. I wonder if my ceiling could handle the weight.
Quick answer is no.
Trusses typically have their load rating stamped on them.
You could however build a beam to distribute the weight.... that's what we did for our '07 Wrangler Hardtop.
The vertical steel column is only used when removing the hardtop.
r1ch999999
r1ch999999
Rich
Nashua, NH
Software Engineer
I was afraid of that, I don't know what my roof looks like under the sheetrock. I've been tempted a few times to add a center beam to my garage.
SafetyDan
Dan
Oxnard, CA
RCMUSTANG
Ray
Los Angeles
2017 Fusion 1995 Ranger
I have the overhead with a harbor freight electric winch. Once it's up a high as i want i run a pair of ratcheting straps underneath to take the load off.
Rinn69
N. Central Iowa
Retired USAF MSgt
How much does that Wrangler hardtop weigh ?
That's what I was thinking too. Seriously, what does a topper weigh ?? I just looked at a fiberglass, full windows, for an F-150 and it was 190 lbs.... That triple 2x6 (?) beam with a steel jack post seems a bit excessive for a topper, but I'm not an engineer. If it were me, I'd screw (with construction screws, not drywall screws) a 2x4, layed flat on top of the rafters, contacting and screwed to 4 or 5 of the rafters, one for the front and one for the back. To truly spread the load across all the rafters evenly, a person should make a solid connection at every rafter. But that's me.
Deleted member 1634
The best way I've found to think of these things is to put the weight into units you can visualize. A 190lbs is about that same as a lightweight American man, so basically visualize him doing a pull-up on one of your trusses. And then remember that if you spread out the load fore/aft, as well as over a handful across like you're idea, it will be better. You could also hang it in a corner so the load doesn't have very far to travel to get to a support.
At work we often deal in many thousands of pound loads and a lot of the time you get bogged down in just the numbers and not really understand what that means. We often like to use units like Corolla's or bears to help visualize real world. haha
Charley
Next Door
2024 Bronco Badlands Hot Pepper
Cant remember if I asked someone who - or I just roughly figured through research on google and Jeep forums, but years ago to hang the hardtop from my YJ, I sistered serveral of the rafters, then connected them all , basically building a boxed in area. This was a 1997 stick built house with a 3 car garage, using the middle bay. Never had a problem in the 5 summers I had it hanging. And mine was the just the hand crank winch, not electric
HenryMac
The weight of the topper doesn't really matter. The support structure needs to be rated to support whatever the hoist is rated for, plus a safety factor. Our hoist is rated at 450 lbs. So if the safety factor is 3 then the structure needs to be rated for 1,350 lbs.
The design philosophy of the beam is to not load the trusses at all... The beam is actually not even touching the trusses when the removable column is installed.
If you modify the trusses by screwing the beam to them... now your talking about modifying the existing structure of the home... which means building permits. So you don't care? Well be sure to take that all down when you go to sell your home, because the local jurisdiction will care.
Deleted member 1634
A safety factor of 3 seems like quite a bit. I guess I don't know if that's standard in construction, but in aerospace we use a safety factor of 1.5 and those are pretty critical structures.
If it were me, I would just use some rope and a boat crank (rated to the weight of whatever you're planning to lift). Run the rope through a couple pulleys and mount the boat crank on the wall nearby. I've actually done something similar, sans boat crank (just pulled it by hand), to lift and remove the roof cage off my Subaru in the past. If all you're planning on doing is lifting the topper off the truck every once in awhile, then it doesn't need to be too complicated. As long as you understand what you're doing, the load paths, and the consequences of doing it wrong, then go for it.
HenryMac
You're scaring me.... Aerospace safety factor is for things that fly into space... you can't build them to beefy... they'll never get off the ground.
Back here on Earth, for stuff on the ground, safety factors vary. It's rare to find anything with a safety factor less than 3, especially when injury to life, limb and property are involved. Elevators have a safety factor of 10:1. Pressure vessels have a safety factor of 3.5:1.
The issue with trusses is they are designed for environmental loads (snow, wind loads, etc.) along with the upper chords carrying the weight of the plywood and shingles (sometimes multiple layers of shingles). The lower chord of the truss is some times, not always, designed to support sheet rock and insulation.
So if you let the topper hang from the trusses... and then get a snow storm with high winds... is it still ok?
Deleted member 1634
From experience I can pretty confidently say that there are some trusses that can support all that, yes. Maybe not trusses used in places where there's no extra snow load considerations or whatever, but I've done it and seen it done. When I was growing up we'd hang our large homemade wood canoe (probably in the range of 80lbs) from the rafters, as well as pile all the extra lumber and other seasonal gear up there as well. The trusses also supported our 16'x7' solid wood garage door when it was open as well. Not all hung from a single point obviously, but combined there was a lot of weight hanging or resting on the lower truss supports all the time. We would also get many feet of snow piling up on the roof every winter.
I wouldn't hang the topper, or anything around that weight, from a single point on a single truss. I'd distribute the load in much the same way that another poster mentioned with a beam or two across the trusses.
I think the beauty of this, or any other home project, is that we can each do what we want, you, me, OP, anyone. And in the end it only really affects the person doing it (and the others living there). If I screw up and my trusses collapse, that's my problem and my problem alone. It doesn't affect anyone else. That's what I feel gives me the freedom to experiment and try new ideas at home, my home. I wouldn't do it on anyone else's home, but I would support whatever they decided to do, even if I thought it was wrong (and I have many times), because it's their home.
HenryMac
That's a baffling comment and one that reinforces the old saying "Free Advice is Worth What You Paid For It". Caveat Emptor.
r1ch999999
r1ch999999
Rich
Nashua, NH
Software Engineer
AFAIK I have no center beam in my garage, and was told the trusses were really only designed to hold up the door and the sheetrock. I'd love to get rid of the sheetrock and add some supports.
