HoosierT's Lightning Blue Ranger Build
HoosierT
HoosierT
Tyler
Fishers, IN
Hi Tyler,
Great! Looks good...the aluminum plate will be better but you have done a great job in thinking ahead!:thumbsup:
best,
Thanks Phil! Quite a compliment coming from someone with much more experience than myself. I’m trying my best to do everything the right way with no shortcuts. Though many will probably scoff at me having decided to drill holes through my rails.
HoosierT
HoosierT
Tyler
Fishers, IN
Next step in the build is the fridge setup. I initially had bought a GZ Yeti 400 lithium but I returned it and have decided to build my own auxiliary battery using 190ah raw LifePO4 cells and a 3D printed box to hold it, the BMS, and I’ll have 4 usb and 2 12v sockets flush mounted on the top. It occurred to me that I can do without a power inverter within the portable battery itself as I’m so used to ultralight backpacking that there’s virtually nothing I’ll need AC for on the trail. I’ll use gas for anything that needs heat and I can charge my drone or laptop with the 150w ac plug inside my truck.
I’m going to put down plus nuts in the floor of the bed and build my own fridge slide with extruded aluminum and some HD drawer slides. The diy lithium battery should power the fridge, camp lights, and charge misc stuff for the better part of five days. I’ll be installing a Renogy 20a dc to dc charger run from the starting battery back to the bed and terminating that cable with an Anderson connector. The battery will have two Anderson connectors flush mounted in the rear. One for input from the dc charger, and the other as a direct 12v output to the fridge. This should negate any need for me to have to carry any solar panels.
HoosierT
HoosierT
Tyler
Fishers, IN
A few pictures with the RTT mounted. Yes I did plan for the overhang. I needed the xl version of the Condor to fit my family of four.
r1ch999999
Rich
Nashua, NH
Software Engineer
Dakota Lithium has some interesting stuff. I use Battery Shark for a lot of my battery needs too.
Desert Rider
Ed
Albuquerque
1965 Mustang 1976 Bronco 1999 Super Duty
Also, yes it clears my garage door by about an inch...:whew:
My truck sits about the same height as yours, as I am running the same ICON Stage 2 suspension dialed in at about 2.5” lift, 1” rear blocks, and slightly shorter tires (255/75/17 BFGs). I am interested in whether a RTT setup will clear my garage door (height) once I install a Diamondback HD cover (about 3” higher than bed rails), front runner bed rack posts and load bars (adds about 10” height), and IKamper Mini RTT (adds 13” height).
How tall is your RTT ?
How tall is your Bed Rack (from top of bed rail)?
What height/opening is your garage door?
Thanks in advance for feedback!
HoosierT
HoosierT
Tyler
Fishers, IN
Np at all.
7’ garage door
Bed rack is 10” tall off the bed rails
Tent is 14” tall.
You should be fine I think.
Desert Rider
Ed
Albuquerque
Np at all.
7’ garage door
Tent is 14” tall.
Thanks!
BTW, you continue to inspire me with all the top notch mods you have done to your Ranger!
HoosierT
HoosierT
Tyler
Fishers, IN
Thanks!
Hey thanks man, I really appreciate that! I’m having a blast modding it.
HoosierT
HoosierT
Tyler
Fishers, IN
So I used my points and ordered Lund Sport flares through the dealership. However, I ended up receiving bushwhacker extended flares. But what I got was the ones withOUT the fake bolt on which is good because it not a fan of those. So...I stared at them for a bit and decided I might actually like them. What do you think?
Living The Dream
Now your wheels need to stick out farther :D
Aren't you running 285's?
Those flares almost make them look small.
HoosierT
HoosierT
Tyler
Fishers, IN
Lol yea 285’s. I don’t want them to stick further, I had to get these because I was getting rock chips without them and I don’t like mud flaps.
HoosierT
HoosierT
Tyler
Fishers, IN
Got the new stainless downpipe from SPD and installed it today. Took me about three hours. Definitely made it a good bit louder but it sounds fantastic IMO. I’ll get a video tomorrow.
Charley
Next Door
2024 Bronco Badlands Hot Pepper
Did you ever install the Shrockworks skid plate? I am looking at it, but have minor concerns since it uses both tow hook bolt holes, and like you I have a Warn bumper which uses the front tow hook bolt hole.
HoosierT
HoosierT
Tyler
Fishers, IN
I’m still waiting for my set. However, I spoke with Justin in detail and he even pulled CAD for the warm bumper and said it won’t be an issue at all. Hopefully I’ll have them soon.
